first E85 turbo lancer?
Old May 12, 2009 | 03:18 PM
  #31
ambystom01's Avatar
10:1 would be a really cool setup. I remember somebody else did this (and I was going to) and the results were good.
Old May 12, 2009 | 10:30 PM
  #32
4g94T's Avatar
i believe it was a mirage?
Old May 13, 2009 | 05:42 AM
  #33
senate6268's Avatar
No, he went 11.0:1 or 11.5:1 (I forget which). Made some great numbers at the dyno. We kept telling him his motor wouldn't last long with that setup and sure enough...
Old May 13, 2009 | 09:03 AM
  #34
cincy's Avatar
with a proper tune and octane, its not a problem. Most drag cars are running way more compression with c16 and way more psi. If you go to the 8-9 turbo section, most evo guys going e85 only are running 10+ to 1
Old May 16, 2009 | 01:48 AM
  #35
4g94T's Avatar
update:
after 80 miles (city driving) Im down to half a tank. So thats about 12-13 MPG
cold engine start ups are smooth, its when the engine is hot is when the start up is not so smooth, it will start up though.
Old May 17, 2009 | 09:55 AM
  #36
Demon_ni2's Avatar
sounds about normal on gas mileage.. im doing a little better now since it was retuned again.
ill be at about 140-160 miles by half tank, on highway driving and staying out of boost.. city, ill get about 120 on half tank.. been averaging 200-240 miles on a tank, and that includes plenty of boost time
Old May 18, 2009 | 07:39 AM
  #37
cincy's Avatar
keep in mind he is using 25% more fuel to keep the same a/f. So if you avg. 20mpg, you would get 12mpg with e85. Helps when its $0.10 cheaper than 87oct.
Old May 18, 2009 | 04:02 PM
  #38
Demon_ni2's Avatar
only 10 cents ? wow.. its like.. 30 cents cheaper then 87 by me..
Old May 18, 2009 | 06:46 PM
  #39
cincy's Avatar
$2.38 87oct
$2.28 e85
Wish it was cheaper than that
Old Aug 10, 2009 | 11:57 AM
  #40
4g94T's Avatar
gas here now is ~$3.10 for 87
and E85 is ~$2.35
also for those curious about smog testing and E85.
i passed with my current setup, all i added was my cat and lowered my idle
im laughing straight to the DMV
Old Aug 19, 2009 | 08:53 PM
  #41
BlackOperative's Avatar
Originally Posted by Chameleonzero
are you using a piggy back system or an ems.. You physically can't run a lancer 4g94 on 14psi with stock internals. The pistons and rods will only hold 10psi at most on a really good tune. I have to call this one a flop
Not so..... I've been running 14psi on stocks for about 8 months on te split sec. piggy back on 91 octane...... It can hold 14psi, Ive been to 17 on stocks....
Old Aug 19, 2009 | 09:01 PM
  #42
Originally Posted by senate6268
It's pretty much "the chicken or the egg." The rods easily get bent from too much cylinder pressure or detonation and the pistons crumble from too much cylinder pressure, heat or detonation.
Either way, most of us aren't in the position to make an experiment out of how much the stock pistons/rods can take by slowing turning up the dial.
Like I said, I've ran 17 pounds before on the stock internals... Now, do realize I have a head shim installed, head studs and I tuned it properly, I wouldnt suggest it to anyone who cant do any tuning themselves, a slight kaboom may be in order haha. Anyways, I've had the head off and all is still well with the pistons, of course I am doing internals in a month, 22psi on my evo9 turbo, should be quite interesting. I'm pushing for 400+ in the upcoming year.
Old Aug 19, 2009 | 09:07 PM
  #43
Im going with the 8.8:1 wiseco pistons instead of the decomp head gasket, might as well right?
no E85 in your area?
Sorry for all my posts, but that is the correct way to go..... stay away from head shims if all possible...
ALSO FOR ANYBODY PUSHING RELETIVELY HIGH BOOST ON A STOCK LANCER... Just so you all know, I have been on 14psi for 8 months.... it will take the most toll on the rings.... they are starting to leak quite badly, burning a fair bit of oil, so be sure to do pistons AND rods at the same time, NO MATTER WHAT! I had 12,000 miles on my lancer when i turboed it, I now have about 25,000 miles on it, motor is about done, power is being lost, clutch is slipping.... Ready for the overhaul. Anyways, happy boosting everyone...
Old Aug 19, 2009 | 09:17 PM
  #44
Originally Posted by D420mac
I saw the many posts, vs the small amount of posts.
I was just interested to read what you guy's had to say.
I have no experience with the 4g64, I've got a 4G63 and 4b11
But yeah boost is good, Just remember pushing it your asking for something to break. Just save your money just in case it blows, and crank it up to 14lbs. I'm not sure how E-85 will help you, I don't think it's a heat power issue. It's going to be too much cylinder preassure for the stock connecting rods to compress thus breaking them.
Where as the race fuel/ E-85 allows you to advance timing and crank up boost because of it's octane properties, it can handle higher pressures before it'll detonate allowing higher boost.
Bottom line if your rods can't handle the boost pressure it doesn't matter what fuel your running.
I'm not an expert so don't quote me that's the way I understand it.
Your right.... Boost technically has nothing to do with it, its the horsepower that breaks a rod.... but just to make it easier for everyone to understand, about 14 is the highest you should go, and thats on a decomped motor, I wouldnt go above 12 on a stock 9.5:1 motor, your asking for trouble. Also about the post below this one, you are also correct that different setups produce different results..... but 14psi is really not that much to where the size of the turbo is going to make hat uch of a difference.... 10psi on an evo 9 turbo for instance is way below its full efficiency, as are most of the turbos custom fitted to lancers, so 14 is just a rough estimate of how high to really push this stock motor. And Im NOT tying to be a smartass here guys, really im not, Ive just had quite a bit of experience with this motor, good and bad.... One being that if your boosting even at 7psi, you will lift the head gaurenteed.... buy headstuds. anyways, Ill stop posting so much here haha, sorry everybody
Old Aug 19, 2009 | 09:27 PM
  #45
Actually you make more power on lower compression in a boosted motor.... just saying. Anything with high boost, like drag cars, run around the 8-8.5 mark. The problem lies in fuel delivery.... Lets take 50psi for example. The amount of fuel needed to keep a correct A/F ratio is very high. With a high compression engine, there honestly isnt enough space for that much fuel.... you will hydrolock the engine with that much fuel in a 11:1 motor boosting 50psi. Also, even with C16 race fuel, the heat that would be produced from a 11:1 motor boostig that high would just melt everything..... Again, not trying to be a smartass, just trying to keep things cleared up..... yes you can run awsome numbers on a higher comp motor, just know that the lower the compression, the more boost is possible, and thus the more power can be made. OK ill stop posting now haha, havent been on evoM for like a year
