RIPP MODS SDS supercharger system thread (MERGE)
Old Dec 4, 2003 | 09:43 AM
  #91
.L.'s Avatar
.L.
Originally posted by pickleknock
im still wondering why that throttle body area is corroded... anyone know?
if you take a look at all the pics, it looks like the whole engine bay is just REALLY dirty. probably normal due to all the work being done on the engine. well.... thats my guess anyway.
Old Dec 4, 2003 | 10:04 AM
  #92
Guru_Del's Avatar
man i am just glad to see aftermarket support for this car.
Everyone keep up the good work and i think this car has more potential than first thought
Old Dec 4, 2003 | 10:17 AM
  #93
HobieKopek's Avatar
Originally posted by Drive02Lancer
i know thats the bar, what i was saying is have that bar still..but instead of the s/c'r way over on the right side of the car by the battery...maybe in the middle running in front of the manifold...if it would fit. it'd be a smaller bar...and easier to spin..robbing less HP..but say it robs 15HP from the bar for it all to spin...ur still gaining 70-100+HP after its done....just a suggestion lol.
You'd be sucking in hot air. Very VERY hot air.
Old Dec 4, 2003 | 10:22 AM
  #94
Bitnode's Avatar
swweeeeeeeeeeet!!! any price yet?!?!? will it be a bolt on kit?
Old Dec 5, 2003 | 10:06 PM
  #95
Drive02Lancer's Avatar
yeah im interested to!!! i dont got the money now and i won't for a little while...but i want the S/C'r =)
and im not the biggest mechanic guru but if its 'bolt-on' like that'd be the coolest
Old Dec 6, 2003 | 11:56 AM
  #96
i_love_spool's Avatar
Looks better than the RRM kit....I like where the turbo is placed, not crammed in front of the engine.
Old Dec 6, 2003 | 12:18 PM
  #97
HobieKopek's Avatar
That's the compressor. Turbines don't exist on superchargers. The turbine is the exhaust side pinwheel (for lack of a better way of putting it) of a turbo.
Although, technically speaking, a turbocharger is a type of supercharger.
Old Dec 9, 2003 | 09:47 PM
  #98
Malak's Avatar
Well, I hope RIPP gets all the kinks worked out and have a solid, newbie friendly kit to put out like ive been hearing out there. Well, with the exception of one or two people...
The idea of HP ready for me each time I shift without the need for spool is nice
~Malak
Old Dec 11, 2003 | 08:21 AM
  #99
RIPPMODS's Avatar
Of course, the system installs quickly, it's nearly the simplest system we have...
Install break down:
Remove Battery
Install Fuel pressure reg.
Remove header
Remove oil pan
Install no weld oil return
Install oil pan
Install header
Remove Power steering pump put aside IN CAR (not lines)
Install new power mounting bracket
Mount PS to new bracket
Mount SDS Bracket
Install oil feed lines
Install injectors
Fuel pump
Black box
SDS Belt
Check over
Run
6-10HRS
Rippmods
Old Dec 11, 2003 | 11:23 AM
  #100
JVlancer's Avatar
When you say No-Weld for the oil return line do you mean that you use JB weld or something.. and do you need to Tap a line into the bottom portion of the block.. and also .. where do you guys tap your feed lines into.. just curious and getting some of the questions out of the way for the guys who are going to get this kit... and im assuming it comes with all the T's needed in the kit.. for vaccume lines and what not..
Old Dec 11, 2003 | 11:50 AM
  #101
pjal84's Avatar
The No-Weld line is quite literally that. It threads into the oil pan using an interesting nut/hose combo, so no cutting/welding is needed.. They've posted the pic elsewhere and it should be on their site.
Old Dec 11, 2003 | 01:59 PM
  #102
Boeturbolancer's Avatar
yeah its an easy little fitting you basically just drill a hole and put the fitting in... a nut on the other side tightens on a seal and your done. No tapping required.
Old Dec 11, 2003 | 02:05 PM
  #103
wow....i think i could do all that stuff lol. any word on price yet?
Old Dec 11, 2003 | 02:07 PM
  #104
u said to run it 6-10 hrs...u mean just let it idle? or lightly drive it? thats a long time to let it idle, i guess its to get all the oil and stuff running through the system and to get the ecu reset to the much added power...right?
Old Dec 11, 2003 | 02:15 PM
  #105
gbwaacha's Avatar
i think he meant it takes 6-7 hours to do...but im not sure
