Top Speed??
Old Oct 4, 2010 | 05:10 PM
senate6268's Avatar
Originally Posted by Demon_ni2
This might sound stupid.. I donno.. haddent really thought it through..
But since people have been swappin the 4g64/63 motors.. and using out bellhosing and there trans.. couldnt we do that on our 4g94 also?
ihavent sat down and actually looked at all the gearing differences between eclipse/galants and whatever else that has a trans that might work.. auto or manual both should be geared a little longer.
swap trans, but stick to our bellhosing, and swap axles... couple transmissions out there that would bolt right up (if im not mistaken) all have much longer gearsets then ours.. would definately increase our top speed with a longer gears
Yes and no. You would be able to use a F5M42 transmission from a 3G Eclipse or Ralliart and bolt it to a 4G94 bellhousing. However, you would also need to swap the Lancer differential into the trans to use the Lancer axles. The Ralliart axles would not work because the passenger side uses an intermediate shaft. I believe the 3G Eclipse has a wider wheelbase and the axles would create fitment issues.
The gearing between the 3 cars is not all that different. Here are the gear ratios for the three different F5M42 transmissions:
F5M42-2-R7B5 Lancer Ralliart
1st - 3.583
2nd - 1.947
3rd - 1.379
4th - 1.030
5th - 0.820
Fin - 4.04
F5M42-1-F7 Lancer OZ
1st - 3.583
2nd - 1.947
3rd - 1.379
4th - 1.030
5th - 0.767
Fin - 3.722
F5M42-2-F6NJ 3G Eclipse 2.4L
1st - 3.455
2nd - 2.056
3rd - 1.370
4th - 1.032
5th - 0.850
Fin - 4.133
Old Oct 4, 2010 | 06:34 PM
Demon_ni2's Avatar
hrmmm.. according to top speed calculator.. that means the lancer trans has the highest possible mph assuming the same tire choice on each trans... hrmmmm
http://www.catherineandken.co.uk/sti/tyres.html
Old Oct 4, 2010 | 07:48 PM
lilazn64's Avatar
Red lined at 137mph on straight hwy
Old Oct 5, 2010 | 10:42 AM
03lances's Avatar
According to that calculator I would top out at 152mph at redline, sounds pretty close
Old Oct 5, 2010 | 11:21 AM
Demon_ni2's Avatar
ya mainly all depends on your tire choice.. But dont forget that means ur speedo is probably off by 20+ mph if ur runnin some crazy wheel/tire setup..
Old Oct 5, 2010 | 11:26 AM
WangMan's Avatar
cop radar said he got us passing him at 140
please elaborate!
Old Oct 5, 2010 | 05:25 PM
Demon_ni2's Avatar
lol? no....
errr ok..
my dad has a viper(well 2 actually).. and he had his buddies rims off his older mustang that fit on my car.
think i had.. 245/55/17 tires on the car(maybe it was 255/65, i dont remember).. could barely turn the car at all.. straight line only.. decided that my dad pacing me up to top of 4th (automatic) would tell me how fast the car can go.. he said i was doing 145 when i let off.. cop said he clocked us both doing 140.. but cop did also say his radar was only calobrated for 90mph or soemthing like that and he was sure we were going faster then what it read.
He didnt even attempt to pull us over, just tried to catch up, and catch us once we slowed down.. no tickets were given.. but he did want to check out the old setup cuz he thought it was cool that my car was actually going that fast, since it was just a 'lancer' , and he has actually stopped by the house a few times to check out my new setup. he knew my dad 'to an extent' (he had pulled my dad over twice before and talked to him about cars a few times)
Old Oct 26, 2010 | 05:21 PM
03oztim's Avatar
Haha that is just crazy. I wish I could go 140 and not get a ticket even after being pulled over
Old Nov 21, 2010 | 08:50 AM
TaKTikZ's Avatar
No shot that would be cool. I've had mine for to weeks and only have RAM intake and i hit 100 on the interstate at 4k rpm. I let off the gas then because I didn't want to get a ticket. Lol
Old Nov 21, 2010 | 09:06 AM
pao's Avatar
pao
until she can no longer go any faster
Old Nov 21, 2010 | 01:40 PM
03lances's Avatar
Only gotten up to 130. She got there pretty quick but I am a pansy and let off lol. Passing too many cars too quick did not feel like getting a reckless or worse.
Old Nov 22, 2010 | 07:22 AM
Lumpydonut's Avatar
Mine gets to 120 in 5th but then just kinda stops getting any faster which sucks cause at 120 I'm only at like 4k. I want my other 2k!!!
Old Nov 22, 2010 | 05:49 PM
steven121's Avatar
If you connect a hose from your a/c towards your rear window you might be able to get that other 1k
Old Nov 22, 2010 | 08:26 PM
Demon_ni2's Avatar
huh? what are you talking about..
Old Nov 22, 2010 | 08:30 PM
BlueRalliart's Avatar
120 mph
