Hey guys got a question about turboing
Old Oct 26, 2010 | 02:05 AM
steven121's Avatar
Originally Posted by 03lances
I am told 0-1v is generally false knock 1-2v may or may not be and 3-5v is generally real knock. This is coming straight from one of the main tuners from english racing so I am inclined to believe him
do you think installing an evo knock sensor will cure most of the problem?
I know when I boost you can feel a difference because the ecu flips out and pulls timing
Old Oct 26, 2010 | 05:32 AM
Mitsu.kid.02's Avatar
Thats good info, ill make a note of this! Because whenever i hit the gas hard at real low RPM, like 1,500 to maybe 2,400 i get knock 5, then 4, 3, 2, 1, 0 while accel. But the voltage is like 1.2v and it never gets higher, it always decreeses! Ill look for this in my logs from now on, to determine if the knock is real or not!
Old Oct 26, 2010 | 06:31 AM
03oztim's Avatar
tuner in tx
Originally Posted by 02-Lancer-Es
Hmm i didnt know you could run up to 15 pounds !
I might just turn it up to 12 Psi
Haha
Is it still as safe as running 10 pounds though ?
As far as tunning it go's i work with one of the best tunners in Texas so that wouldn't be a problem .
hey 02-lancer-es who is your tuner in tx and where is he located. i am gonna be needing a tuner and i only live like 3 hours from tx, and i cant find anyone good here in oklahoma
Old Oct 26, 2010 | 08:58 AM
HornstarBU's Avatar
I've heard similar advice, but also advice against using voltage to determine false knock. Some say a "sharp" peak helps to show real knock, and that slow steady lines of knock voltage that just barely creep above the threshold of "what is knock" are probably engine noise. Still, this is a very difficult thing to see in the graphs.
As for an evo knock sensor, I think there are really 3 things at play here.
1. the knock sensor
2. the knock sensitivity, multiplier, single and triple gain settings
3. the engine itself
Each of these things is "tuned" for a 4g6x engine, but we have a 4g94 engine. They probably need to be adjusted to work right, and also....the added noise of the turbo and performance has to be taken into account. The thing that concerns me most of all, is what JRR says. He got an evo ECU, and put settings in for his fuel/timing/maf/idle and what not, but says he left his knock settings "Stock". From what i can tell, the evo engine is less sensative in low rpm, the same in mid range, and more sensitive up top. This may not be true, because the single and triple gains are different, so really, I have no idea how to compare the 2. My plan was to copy all the settings i can over, and just see how it goes.....but that scares the crap outta me. I asked this question in the evo ecuflash forum, hoping someone will give us some good advice (umm...roadspike or senate, or maybe even a tephra god)
brenner
35
Aug 25, 2010 10:05 AM
lockadam2112
Dec 22, 2007 10:46 AM
Most-Wanted
61
Sep 4, 2006 08:51 AM
bigboybusa
17
Oct 16, 2005 07:22 AM
AznFlip
10
Jul 30, 2005 01:38 PM
