what is needed.
Use the search feature, there are tons of great info on turbo info! If you plan to do your own build, do ALOT of reading and research. The 4g94 motors are an economical motor, you cany put a turbo on and turn the boost to 15 and expect it to run long. They require alot of attention, by this i mean good tuning, plenty of fuel when its needed, and if you want to play things safe get head bolts/ studs. Although generally 5-8 PSI you wont need headbolts/ studs, its a good safety backup. Make sure you read about the fuel requirements. If you plan on tuning your car yourself, you will need a wideband 02, evoscan or mitsulogger (logging tools) and a tactrix cable to re-flash the ecu. Read the build threads in this section, they all explain the processes and whats required for a turbo build. The most popular build by far is the custom 16g turbo setup
Im pretty sure the RRM kit is pretty good! i have heard good stuff about it! www.roadracemotorsports.com and check out the turbo kit they offer for our lancer!
An intercooler can be added like a cold air intake. It can be done, and it can be functional to lower the air temp. However you will prob get alot of crap for having it installed on a non-turbo car because many people just install a CAI (cold air intake) wich does the same.
i plan on getting a turbo. but i can only afford to get it in pieces i would start with the intercooler and then get the rest later. it would be a waist of money to get the cold air intake and then just turning around and getting the turbo and intercooler later.
I also did my build in buying parts instead of an actual kit.
ok i hear ya there but the issue is that it may be a while before i get the rest of the kit due to money but i want the extra boost the intercooler would give me. do you know of any chips i could get to get a little boost while i wait.
Ive tried various "power adders" Even if you bought a chip that actually did anything. Oods are it would cost you minimum $500+ and might gain 2whp maybe? Sorry the $60 ebay chip wont do jack.
