turbo clearance help
Old Mar 14, 2011 | 11:26 PM
burner67's Avatar
Unhappy turbo clearance help
well I was test fitting my megan manifold today and it bolts up fine but the turbo wouldnt clear this big pipe.
i grinded off the piece of the turbo that housed an uniportant screw hole for the evo oil feed line and its still hitting a little.
any advice on what I could do would be great thanks!
Attached Thumbnails turbo clearance help-2011-03-14_22-06-35_238.jpg   turbo clearance help-2011-03-14_22-06-49_235.jpg
Old Mar 15, 2011 | 01:43 PM
senate6268's Avatar
You runnin' a SpeedCorps manifold or a Megan Evo manifold with a 4G94 flange welded onto it?
Old Mar 15, 2011 | 01:52 PM
burner67's Avatar
Its a megan manifold re drilled to fit 4g94.
Old Mar 15, 2011 | 02:32 PM
03lances's Avatar
Common problem just have to grind down that nub on the Turbo until the manifold sits flush.
Old Mar 15, 2011 | 02:46 PM
burner67's Avatar
Yeah its ground down all the way flat
Old Mar 15, 2011 | 05:45 PM
burner67's Avatar
well i just tightened the flange all the way down and i guess it fits probly dented the pipe a lil but whatever
ellyottlin
Apr 26, 2009 06:27 AM
Jim in Tucson
May 29, 2008 10:45 PM
splurge3188
Feb 9, 2005 05:07 PM
bovbilly
18
Jan 29, 2004 05:39 AM
