t3 turbo manifolds
Old Apr 3, 2012 | 07:15 PM
  #31
beautifulpunk's Avatar
thanks bro.. it has takin time but its worth it.. cant wait to see what it does with a whole setup.
Old Apr 4, 2012 | 08:32 AM
  #32
Green_Bandit's Avatar
Great job man! It looks like it's coming along.
Old Apr 4, 2012 | 10:23 AM
  #33
Its going good..sadley I am not going to use this manifold.
I am sticking with the T3 set up...this one is for a good friend
Old Apr 4, 2012 | 10:30 AM
  #34
Also did some suport brackets for speedcorps..
to help with cracking issue on the manifolds they sell
Old Apr 4, 2012 | 12:49 PM
  #35
Oooh! Intresed! Info!
Old Apr 4, 2012 | 05:29 PM
  #36
here is a pic of it on the car..nothing special, just a bracket. It uses an existing bolt hole on the block and the other side goes to the o2 housing.
Pm me for more info
Old Apr 5, 2012 | 11:39 AM
  #37
jakermeister's Avatar
Looks awesome man
Old Apr 5, 2012 | 07:08 PM
  #38
Thanks guys..the manifolds will be avalible to in the future along with downpipes to match
Jake thanks for all the imput on this bro..
Old Apr 28, 2012 | 08:18 PM
  #39
well the manifold is evo8 16g manifold is still "in devlopement". me and jake hit a few snags but not bad considering it was built with just pictures. More to come on this.
The T3 is on the back burner for now
Old Apr 28, 2012 | 08:36 PM
  #40
Its just a bump in the road but we'll get there.
Old Jul 1, 2012 | 07:25 PM
  #41
Its been awhile since i posted. Things have kinda shifted focus since i started this thread. Jake and I have been working on a 16g manifold for the lancer guys and i have kinda put the t3 manifold on the back burner for now.. Still have support brackets avalible for the guys running the sc manifold if needed, just pm me. I will keep updating as progress moves forward
Old Jul 16, 2012 | 07:16 PM
  #42
here is some pics of the evo8 manifold for the lancer and you can see what it clears. the turbo clears with a 3 inch intake pipe
Attached Thumbnails t3 turbo manifolds-my-phone-388.jpg   t3 turbo manifolds-my-phone-343.jpg   t3 turbo manifolds-my-phone-382.jpg
Old Jul 16, 2012 | 07:23 PM
  #43
me and jake (jakermeister) have been working on this for a few months now. we have worked over idea after idea and this is what we got. Jake will be the first to get this as well as the dp and ic to come later..
need everyones opion please
Old Jul 16, 2012 | 09:16 PM
  #44
Demon_ni2's Avatar
first thing to say..
J pipe.. (lower intercooling pipe) off an evo wont work with a slightly relocated manifold. so.. might also require a J pipe made to go along with stock style turbos to hook it up to intercooler Easilly..
other then that... looks pretty good.. like how u used the bigger pipe (2.25?)instead of that dinky 1.75 tubing. (that should help with heat some) and flows alot more air. which every little bit helps even thought its not 'needed'
welds arent the prettiest.. but pretty doesnt matter as long as there strong and wont break.
Old Jul 17, 2012 | 07:36 AM
  #45
Thats what welds look like when your up till 4am
