rocker arms hitting valve cover
Old Mar 3, 2012 | 09:46 PM
Demon_ni2's Avatar
lash was right. we did that before we started it. no oilpressure build up needed for solid lifters
Old Mar 4, 2012 | 08:42 AM
Demon_ni2's Avatar
ok... so far this morning.. going down all my basses..
timing. is zero'd out.. so its right
spark plugs were not in that tight.
compression (L>R) 115/128/128/128
right two cyclinders 3 and 4 had oil on the spark plug. 1 and 2 were dry n normal looking
Old Mar 4, 2012 | 10:11 AM
Demon_ni2's Avatar
ok i give up. cant find anything obiousely wrong. must be the pistons or wrist pins just like on zulus motor..
Old Mar 4, 2012 | 10:16 AM
ryancb's Avatar
It wasn't pistons or wristpins it was bad machine work
Old Mar 4, 2012 | 10:21 AM
krisgoodwin84's Avatar
Haha hopefully its not as bad as the block that ryancb got cause that would suck!
Old Mar 4, 2012 | 10:43 AM
Demon_ni2's Avatar
car idled fine for hours.. 2nd or 3rd time in boost.. not even 20-30% throttle it started.. and hasnt stopped yet.
Old Mar 4, 2012 | 10:51 AM
slatermvp's Avatar
time to take the head apart and see what you got.
Old Mar 4, 2012 | 12:48 PM
Demon_ni2's Avatar
took it to my engine builder once already. he said it was just a failing rocker arm.. new rocker arm.. idled just fine.. 2nd tim ein boost same issue.. rockers hitting valve cover. not even wide open throttle...
even idles normal.. just nasty noise.
recorded it this time.. sounds even worse now. but still.. idles spot on 1200 no issues. even revs with no misfires or nothing... sounds nasty now. maybe its something underneith.. but bearings were all checked. all good. and rods were good.. didnt pull the pistons out.. so could be a piston or wrist pin issue.
Old Mar 4, 2012 | 01:51 PM
Demon_ni2's Avatar
videos im uploading
attempt to start(but batery dead)
thought it was funny. so i uploaded it
http://www.youtube.com/watch?v=ddu1I...ature=youtu.be
and idleing..
http://www.youtube.com/watch?v=XTTES...eature=channel
Old Mar 4, 2012 | 02:24 PM
Demon_ni2's Avatar
and as a reminder.. the noise u can hear.. is the rockers hitting the valve cover.. i have nice U shape dents on the inside of the valve cover.
Old Mar 4, 2012 | 02:51 PM
03lances's Avatar
Just pound up a little where the marks are and be done with it
Old Mar 4, 2012 | 03:00 PM
Demon_ni2's Avatar
lol
sorry that didnt work.
Old Mar 4, 2012 | 03:01 PM
02-Lancer-Es's Avatar
Mine have always been like this , oh well Haha
Old Mar 4, 2012 | 03:04 PM
Demon_ni2's Avatar
? huh
Old Mar 4, 2012 | 04:32 PM
beautifulpunk's Avatar
ls1 guys use a high rise vc when they have done valvetrain work . a higher vc is the only way i know to cure the problem with rocker arms hitting
