Coil problems at high load
Old Jun 4, 2012 | 12:24 PM
audiofan's Avatar
I'm posting this for a friend, the car is a lancer OZ with a custom turbo set up. Block is built, was running a gt28rs, now a precision 3231E with 22 pounds of boost.
The problem is that at high load (WOT) and high RPM, sometimes in 4th, sometimes in 5th, the car just turns off, the coils make a clicking sound and the car shuts off, he has to turn key off and on again and the car will keep going like nothing happened.
It is a random problem, not always happens. It happened with only 10 psi, and also with 22 psi. The EGT's are fine (1550 F max), temperature is fine (safe), AFR's good, there is no knock since he disconnected the sensor, new colder plugs gapped correctly, etc etc.
We have no clue why this is happening, any ideas? or what to check?
Thanks for the help
Old Jun 4, 2012 | 08:30 PM
elguareali's Avatar
Bump!!!
Old Jun 5, 2012 | 05:23 AM
Demon_ni2's Avatar
sounds like blowout.. kinda..
check plug gap. should be about .02.. not factory .044
Old Jun 5, 2012 | 11:09 AM
audiofan's Avatar
They are at .028, will try to lower them a bit More and see if it helps
Thanks
Old Jun 5, 2012 | 04:43 PM
slatermvp's Avatar
If it doesn't help, it might be time for him to try and do a coil on plug set up. Just a thought.
foxbat
Sep 30, 2016 08:31 AM
detroit pistins
18
Jan 22, 2014 11:37 AM
ziad
Jun 12, 2012 08:22 PM
bandit09
May 16, 2012 04:39 PM
Arkitek
18
Jun 27, 2010 06:53 AM
