Turboing my 02 Lancer
Old Oct 23, 2014 | 09:29 AM
marcouxa1's Avatar
Honestly i would turbo the stock motor first if i were you...the difference between stock and turbo is huge....i was at 220whp at 10 psi and the setup is reliable with the stock motor. Get your car in shape first and then u can start to modify it.
Old Oct 23, 2014 | 10:57 AM
Thahomeboyb's Avatar
Alright I guess I should start saving . Im excited 220 is good but more is better haha .
Old Oct 23, 2014 | 10:58 AM
Originally Posted by Boltz.
Turbo'ing an NA car always costs more money than you think. Save up for a new car, no offense.
I dont.feel like making payments really . And I love how no one.has my car and has done what I did with it .
Old Oct 23, 2014 | 12:23 PM
02modlanceroz's Avatar
You'll be surprised with what 220whp feels like in a car that weighs 2750, plus you can only go up from there
Old Oct 23, 2014 | 12:42 PM
Amen to that . Time to start saving
Old Oct 23, 2014 | 02:30 PM
marcouxa1's Avatar
Yea 120hp to the crank and 220whp is a HUGE difference you won't be disappointed i can guarantee you....just make sure you have good compression and no leaking valves or head gasket before you install everything. I made a thread with almost every threads on how to turbo your 4g94 so check it out it will help you a ton. If you ever need help you can pm me too i would be glad to answer your questions. Good luck
Old Oct 24, 2014 | 07:04 AM
Should I check figure out how to do compression and leak.test by myself or take it to a shop , cuase ive never done it before .
Old Oct 24, 2014 | 09:55 AM
marcouxa1's Avatar
You might wana go to a shop if you dont have the knowlage and/or the equipment
Old Oct 24, 2014 | 10:59 AM
viprez586's Avatar
Being completely honest here, if you don't have the knowledge or time to google an engine compression test, you probably shouldn't be doing the work yourself.
You have four options here:
A) Save the money, build it yourself, make a ton of mistakes and cost you more money than you originally thought you would, and potentially end up with a paperweight of a car.
B)Invest the immense amount of time researching your butt off to do things once and do it right.
C) Pay a shop to do all the work for you, this will be more expensive then option A...potentially depending how many mistakes you make along the way.
D)Save up for a factory equipped turbo car as a good starting point. IE: (evo, dsm, etc)
Not being a dick, just pointing things out to you I wish someone did years ago before I dumped tons of money into my 1GA DSM instead of saving up for an evo like I have now.
Old Oct 24, 2014 | 01:14 PM
marcouxa1's Avatar
I gota agree with that though....i'm a mechanics i work with cars every day and sometimes i have to use my imagination to make things fit and be reliable. I don't know your experience with cars but this is not an intake or exhaust bolt on thing... it's not a 1 day install unless you have done it before and there's always something wrong with the fitment. keep in mind this is not a bold on job, you have to be creative and custom make brakets, bend and cut things to make it work.
Old Oct 24, 2014 | 01:22 PM
I appreciate you pointing them out I have plenty of time to research , but even with research I probably will go to the shop for a few things. Maybe not a compression test but I would possibly for a leak test or to have them check the water pump and timing belt etc . I just want ti build this car cuase at the end of the day when its all done I can say its def one of a kind . Its not just an evo
Old Oct 24, 2014 | 07:16 PM
Don't have someone check your belt. It's really not that bad of a job and you should just change it if you turbo. You're only talking like 130 bucks. If you go to change it, let me or some of the guys on the forum know and we'll help you thru it
Old Oct 24, 2014 | 08:40 PM
Alright thanks .
Old Oct 25, 2014 | 06:55 PM
Alright thanks .
Should I try to buy everything at once or buy it in pieces .
Old Oct 25, 2014 | 07:03 PM
Evo 8 16g Turbo
Custom 4G94 manifold: 500.00
Evo 3" aftermarket downpipe:180.00
Wastegate Acuator:
Intercooler/Intercooler pipping: 150.00
Fuel injectors: 02-07 WRX Injectors that are 440cc 250.00i
Evo 9 Blow of valve (BOV) : 100.00
Evo x stock Fuel Pump : 100.00
OBX Oil Feed Line 24.99
Trying to figure out my expenses . What else do I need .
