Super max 4g94 turbo build
Old Dec 23, 2015 | 09:02 PM
tacostacos's Avatar
Okay, I have spent way to much money in order to build a max hp,max boost, 4g94. I need some experienced guys to give me a ballpark in how much power I could make. Block is .20 over, custom 10.5:1 wiseco pistons, k1 rods, re-balanced crank, 262/258 custom cam, arp 625 studs,polished head and intake (plan for 4g93 valve springs) 70mm rc motorsports throttle body,aem fuel rail,aeromotive fuel pressure regulator, 55/75 turbo, turbowerks intercooler. (Need advice on piggyback or ecm ) I need a ecm to run injectors bigger then 550cc. Going close to "all out" but not dangerous. Thanks guys
Old Dec 27, 2015 | 04:45 PM
slatermvp's Avatar
go ecuflash, aem standalone, do not go piggyback. Not sure on horsepower.
Old Dec 27, 2015 | 09:37 PM
02modlanceroz's Avatar
What year car and auto or manual? I'd recommend staying with the stock ecu especially if you're a manual transmission.
Old Jan 1, 2016 | 06:52 PM
marcouxa1's Avatar
There is not alot of high horse power lancers in here sadly...most are daily driven/autocross builds, If you're putting that much money into a lancer im guessing its a manual so you can use an evo 8-9 rom flashed into the lancer ecu, use Ecuflash to tune it and Evoscan as a datalogger to record the data.
Old Jan 1, 2016 | 10:08 PM
Demon_ni2's Avatar
if u look into the Puerto rican 4g93 builds (1.8 liters, but basically exact same motor)
journal t3/to4e 30psi plus nitrous, there making 600+- hp. and there into the 9s in the 1/4.
I ran out of fuel at 21psi and dialed it back to 17psi due to what I think was an electrical issue on going to low impedance injectors, something I do not think would be an issue today with the much larger high impedance injectors available nowadays.. thats why im doing a new t4 setup. 24psi was nasty power on a big borg turbo.
but... im referring to 100% track. i towed my car everywhere because i had zero intent on being able to drive it home.
steven121
15
Jan 7, 2021 09:52 PM
davidcyr41
Dec 24, 2016 06:02 AM
tacostacos
Jul 18, 2016 04:10 PM
DeavenKrietz
Sep 18, 2015 09:55 AM
NoClanSWAT
Lancer Engine Tech
Jan 23, 2013 05:55 AM
