Attn: Turbo Lancer Guys
your ognn have a machine shop do it? its really not that hard to do
when your tapping it you only go in like a little bit wiht the tap cause its tapered that prolly why everyones lines are leaking (going in to far with the 3/8 NPT tap)
and just flushing the pan with oil IS NOT an option you will not get every single burr out of the pan
and there is a spot were a flat head screw driver fits in between the pan and the block in the front by the tranny
i dont thnk i can tap it myslef i since i didnt quite follow what you even said. the shop probably wont charge me much at all anyway.
the space you are talking about taht can fit a flatehead in, is that a space that would allow the screwdriver wedge in vertically instead of horizontally?
Originally posted by Hotshot940
is this a rrm turbo? and if so didn't they send you an intruction manual?
Originally posted by fkrzo
What about going into the valve cover? less chance of leakage and road debris hitting it
its at teh shop right now bc i broke a bolt off in the oil pan. they couldnt get it of either so instead of taking the oil pan off they jsut drilled into the oil pan and put a gasket on it to keep teh oil from leaking. its out in he parking lot right now and all i need to do is wire the fan, fill it with oil, and reattach teh exhaust. im hoping no problems come up.
