ROAD /// RACE STAGE 2 AUTOMATIC In progress
Old May 18, 2004 | 04:10 PM
  #31
IILANCERII02's Avatar
awesome - where did u get that from vince?
Old May 18, 2004 | 04:11 PM
  #32
Guru_Del's Avatar
i think it was a kragen or pep boys. either way it is a generic oil cooler tube and fin time, you can also spend alittle more and get a bar and plate but i was going for cheap hahah
Old May 18, 2004 | 06:31 PM
  #33
KoreanEvoVII's Avatar
dude, u gotta keep us updated on all the mods that you need for the stage2 turbo right now im debating on either getting the rippmods stage2 supercharger or the rrm stage 2 turbo by the end of summer, i really dont want to move my battery to the trunk
Old May 18, 2004 | 08:14 PM
  #34
If you planning at staying at stock boost or no more than whatever the kit gets you, go with the SDS. People who go turbo, go turbo for a reason, TO GO BIG
just remembre that
Old May 18, 2004 | 09:11 PM
  #35
Guru_Del's Avatar
well if you are an auto you still either need to get a race battery or you are moving the battery to the trunk as well cause for the intercooler piping to fit you need to move it.
for stage 2 you need the intercooled turbo kit. a header, a test pipe (i think or maybe a high flow cat), exhaust.
then you will get stage 2 which is piggyback and injectors and other goodies.
Old May 18, 2004 | 09:13 PM
  #36
MayhemOZ24's Avatar
Question
hey guru, one question for you, is your CEL on now after you installed the header and testpipe........
www.roadracemotorsports.com
Old May 18, 2004 | 09:19 PM
  #37
Guru_Del's Avatar
hey mayhem how you doin? glad to finally see you online!!!
so far no CEL. try resetting your ECU. Unplug your negative terminal for 15 minutes then reconnect it. If it goes back on we will hook up and I will scan your car for you with my code reader.
Old May 18, 2004 | 09:54 PM
  #38
MayhemOZ24's Avatar
Hey guru,, I did reset it, but It still comes back on, I also talked to rock and he said it was because of the header, but if your CEL is not on, maybe we do need to hook up and check this out....
Old May 18, 2004 | 09:57 PM
  #39
Guru_Del's Avatar
yeah no worries, lets get together one of these days and I will scan your system and see what the code is.
Old May 18, 2004 | 10:01 PM
  #40
MayhemOZ24's Avatar
whenever you're going to be at RRM and you have time let me know and I'll meet you there...
Old May 18, 2004 | 10:05 PM
  #41
Guru_Del's Avatar
i will pm you next time.
Old May 19, 2004 | 09:43 AM
  #42
so no matter what i still hafta move my battery.. damn, now i gotta take out my system...shouldnt you already have the header with the stage one turbo kit?
Old May 19, 2004 | 10:01 AM
  #43
do you need the intake manifold? if you already got the header or do you run both of them?
Old May 19, 2004 | 10:12 AM
  #44
LancerXtreme's Avatar
Hows it going soo far Guru????
Old May 19, 2004 | 10:49 AM
  #45
Guru_Del's Avatar
so far so good, we are letting the car run with test pipe and header to make sure there are no leaks and such.
