exhaust leak
Old Jul 16, 2004 | 12:56 AM
ozracer4's Avatar
exhaust leak
i keep losing the same nut and bolt off the bottom of the uppipe. i tighten it up and a week later, i lose it again. i know it expands because of the heat and that you're supposed to check it every week or so for a while after you install the turbo, but is there anything else i can do to stop this from happening? this bolt and nut is a real pain in the *** to get on and it never fails to come apart. any help is appreciated. BTW...this is a rrm intercooled turbo kit. thanks.
Old Jul 16, 2004 | 07:42 AM
HobieKopek's Avatar
Have you tried a new nut/bolt rather than reusing the same one?
Old Jul 16, 2004 | 11:08 AM
ozracer4's Avatar
yeah, actually the first ones came out completely...i had to replace them. i heard something about a lock nut that locks onto metal in high heat applications. anybody know anything about it?
Old Jul 16, 2004 | 11:40 AM
Dookie's Avatar
get a washer that has spring tension on it when tightened. We use this on aircraft all the time for vibration areas. It looks like it is cut in half, and one side is bent up a little bit. Should keep tension on the nut, preventing it from backing off.
Old Jul 16, 2004 | 11:58 AM
ozracer4's Avatar
alright thanks. any other ideas just in case?
Old Jul 16, 2004 | 12:00 PM
Dookie's Avatar
Well you could safety wire the nuts too. But you would have to find nuts with little holes drilled in them though. Other than, maybe loctite?
Old Jul 16, 2004 | 12:04 PM
Drive02Lancer's Avatar
yeah loctite or similar products.
zipties haha maybe thats just me....as zipties are holding my maf adapter onto the maf...cuz the original screws weren't long enough
Old Jul 16, 2004 | 12:08 PM
TURBOit's Avatar
yea stick a zip tie behind it, if it melts it melts, then go for locktite
Old Jul 16, 2004 | 12:16 PM
hollywood's Avatar
just use bolts with spring tensioners. they will losen and tighten depending on the heat. maybe look into some kind of locking bolt. but i dont think it is right that u loose bolts that often. check to make sure that everything is instaled properly, if something is instaled wrong somewhere else on ur exhauste then it could be putting extra pressure on the bolts to come undone to release the presure
Old Jul 16, 2004 | 02:02 PM
fkrzo's Avatar
Lock washer, locktite, and Take a screw driver and dent the threads right after the nut.
Old Jul 17, 2004 | 11:49 PM
ozracer4's Avatar
what about teflon tape and a lock washer? if i use loctite, someone told me that i won't be able to get the nut off again. i might need to get it off again.
Old Jul 18, 2004 | 01:22 AM
LancerO-Z's Avatar
Try the lock washer trick ozracer. My wastegate came lose twice.. And the second time I put some lock washers on it and as Rob told me to I "tightened it down with a prudence". Lol. I am pretty sure the lock washers will do the trick. Just make sure they are grade 8.5 or better lock washers, as that bolt has some serious heat flowing though it on spirited drives. Hope that helps.
Old Jul 19, 2004 | 01:48 PM
HobieKopek's Avatar
They make stainless steel locking ties that may help. Personally I'd just try Loctite.
