Spark plugs
Try using copper plugs and dropping a heat range. You should be fine. I've fouled 3-4 sets already, but I'm still in tuning stages, so I'm not in much of a position to comment.
I used to use NGK copper plugs, heat range 7, .033" gap, in my modded Eclipse GSX. Worked great for about 10,000 miles, then it was time to change them.
For reference, the stock heat range was 6. I'd imagine yours are similar..?
I haven't gapped mine down yet. I just need a proper spark plug gapper before I do that...right now though my primary focus is on getting my car running again. After that I'll start to experiment with other things.
