RoadRace Stage 2 help
Stock exhaust has to go for stage 2... you can't run that much boost on a restricted exhaust. The lancer exhaust isn't made to support that. At a minimum you need a header, test pipe, and axle back. The piggy back was tuned for this and you'll be running rich otherwise... also your boost problem could be caused by a high amount of back pressure making it difficult for the turbo to spool. The exhaust you have is killing you. Also check for any exhaust leaks. Start the car... have someone hold a rag in the tailpipe. Use your hand to check for leaks around the header, wastegate, turbo. Do this when the motor is cold and quickly before it gets to hot. If you feel a leak in those areas it will make you spool slower and can keep boost peak down.
Get rid of the stocker exhaust... can't believe no one told you that. Boni had the test pipe and greddy system with a gutted stock header. Thus he was a free flowing exhaust. Please correct this.
What's the best size to go with for non-IC, stage 1 IC, and stage 2 IC?
Do you really need to do anything to the stock header? I thought exhaust system after the turbo were the only items that hinder boost.
stock header is more restrictive, if you get a less restrictive header, such as the road///race header, you will open up the path for the exhaust gases so that they spool the turbo quicker. it doesn't have so much to do with max boost with the header as much as it has to do with spool time so i believe. as for exhaust, either the magnaflow or greddy have both proven to work very well with the turbo set ups on lancers.
Originally Posted by pgmike
nonRRM ppl would say that 2.5in pipes are better than 2.25.
when i say nonRRM ppl i mean ppl that arent boe and rob and gurudel. boni even is trying to upgrade to the buschur dp. that quarter of an inch could make a few hp diff and if you dont have an exhaust already it would be smart to get the larger (2.5) exhaust.
