ripp sds...... i'm done
Old Sep 4, 2004 | 11:28 AM
.L.'s Avatar
.L.
ripp sds...
i was wondering what happened with the o2 sensor problem. and if anyone had any problems with the kit?
Old Sep 4, 2004 | 12:21 PM
pgmike's Avatar
get some pics up man, hows it running?
Old Sep 4, 2004 | 01:43 PM
.L.'s Avatar
.L.
honestly its a REAL long story. i'm trying to get things in order right now. i think member bigvinx was having problems with his o2 sensors. i guess i'm just keeping my mind open to problems. i'll post up all the details soon.
Old Sep 6, 2004 | 09:09 AM
fkrzo's Avatar
I started having an idleing problem and found that an injector seal is bad. I heard an air leak sound and sprayed carb&choke cleaner at all of the connections and heard a big change at an injector seal.
Old Sep 10, 2004 | 06:40 PM
bigvinx's Avatar
yeah man !!!! mine is still off ! 02 problems idle problems ! im just gonna talk to Ross and get those guys to install it i drive 65 miles to work 1 way so i need the car i dont have time to mess around for a couple days with it ! let me know how you make out pm me !
Old Sep 11, 2004 | 09:52 PM
fkrzo's Avatar
I changed the seal and its back to normal. I must have pinched it when I installed my injectors. One was actually broke. Oh, by the way it was pretty chilly here tonight (50 degrees) and my car feels like a rocket. It actually feels like a DOHC 6, alot of high rpm power and good mid range.
Old Sep 11, 2004 | 10:12 PM
bigvinx's Avatar
me to bro i found a cracked seal on the 3rd cylender and still no luck ! im about to give up man !
Old Sep 14, 2004 | 06:04 PM
Dookie's Avatar
A cracked seal? Are you talking about the seal that goes into the fuel rail or the IM?
Old Sep 15, 2004 | 06:33 AM
ZooRacer's Avatar
so far no problems with my car...everything running great ....i already put in over 3000 miles...and have been ripping da car all over long island, queens, and brooklyn....car pulls soon as i touched da gas....Stumpy221 and evo/wrx owners can vouch for me as i have given them rides...and they are impressed how my lancer is running...
Old Sep 15, 2004 | 07:28 PM
fkrzo's Avatar
The rubber seal that goes into the intake manifold.
Old Sep 15, 2004 | 07:30 PM
Dookie's Avatar
Yeah one of mine leaked too. It wasnt cracked though. It seemed like it was shrunk. It's a $5 part at the dealer here. I am going to replace all 4 of them. What injectors are you guys using for the SDS?
Old Sep 17, 2004 | 03:41 PM
bigvinx's Avatar
310 cc venoms ! but they are a little longer than the stock ones ! i found a gasket leak at the front of my cat that could be a problem and a crack in my injector seal that goes in the intake ! could that make my car rum soooo rich it wouldt even run ? and i have to ask ross what if i run my sds without my cat what will happen ? i havent done it i was wondering. one thing though when it was running that thing was like a totally different motor ! and i only went to 5 lbs of boost and i think it goes to 9 to 11
Old Sep 17, 2004 | 04:07 PM
Viciouz's Avatar
i am kinda happy i didn't go with the ripps sds, but ne wayz keep us updated on it
Old Sep 18, 2004 | 09:31 AM
fkrzo's Avatar
My car wouldn't Idle when my seal was bad. I have no cats in my car. Its fine now.
Old Oct 2, 2004 | 03:28 AM
Dookie's Avatar
When you installed your injectors, did the seals that go into the intake manifold seat all the way against the black part of the injector, or did they sit at the lower part of the nipple, in the recessed groove?
