am i missing anything??
Old Sep 9, 2004 | 03:51 PM
turbo03oz's Avatar
alright so i did some research and compiled a list to build a custom turbo kit for my oz
let me know if i am missing anything
310cc injectors
custom manifold and downpipe(got a local friend to do the work)
autometer gauges---egt, boost, air/fuel
t3 turbo, internal wastegate .50 trim
turboxs blow off valve and flange kit
turboxs boost controller
HKS turbo timer w/ harness
spearco intercooler
apex-i S-AFC fuel controller, and possibly a vortech FMU
greddy ic piping
braided oil return/feed lines
i should be able to run 8-9 psi until the internals get swapped out
that was everything i could think of
thanks
Old Sep 9, 2004 | 08:02 PM
Megadeth2118's Avatar
I would probably recommend going with an Electronic boost controller over the manual to help against boost spikes. Better to spend a couple hundred extra to be safe than to blow your engine and fork out a few thousand. Other than that your list looks good
Old Sep 9, 2004 | 09:30 PM
turbo03oz's Avatar
ill keep that in mind
do you think those would be the right size injectors
thanks
Old Sep 10, 2004 | 05:45 AM
livelyjay's Avatar
Getting an EGT gauge and Air/Fuel gauge is redundant. If you don't want to spend a fortune and get a wideband O2 (best air/fuel ratio readings available, but it costs $400+) then stick to just the EGT. A regular Air/Fuel gauge is garbage. Instead of Air/Fuel, get oil pressure.
Old Sep 10, 2004 | 07:58 AM
Hotshot940's Avatar
regular air/fuel gauge = poop stain
dually noted
Old Sep 10, 2004 | 10:05 AM
airlinevomitbag's Avatar
You need a fuel pump and some sort of fuel pressure regulator
Old Sep 10, 2004 | 12:29 PM
Hotshot940's Avatar
no need for fuel pressure regulator with fmu
Old Sep 11, 2004 | 06:33 AM
And a FMU does exactly what? It regualtes and raises fuel pressure based on intake manifold pressure.
Old Sep 11, 2004 | 06:50 AM
maxum17ft's Avatar
so what fuel parts exactly would he need?
Old Sep 11, 2004 | 06:52 AM
hollywood's Avatar
u dont need thoes injectors either. your stock ones are fine for running up to 9 psi. you might want to check your ic piping to make sure you can conect it to your custom piping. and make sure u take it to a good shop
Old Sep 11, 2004 | 07:00 AM
Fuel requirements are a 12:1 FMU at least, the one on Ryan (the TSI kit guys car) is 14:1, and at least 190L fuel pump (Nearly direct drop in and swap) from a GSX or a 255L Walboro (Havent seen one installed yet don't know if its easy or not).
Or you can go Ryans route and stay stock on the fuel pump get a 14:1 FMU and a booster pump for the fuel which you install under the hood right before the input to the fuel rail (I want to say MSD makes this).
Old Sep 11, 2004 | 07:01 AM
maxum17ft's Avatar
the reason i am asking is i am building my own turbo kit to. so he/i would need an safc, a fpr, and a gsx fuel pump, and that is all?
Old Sep 11, 2004 | 08:27 AM
maxum17ft's Avatar
does anyone have an exact list of what is needed to run a turbo at like 4-6 psi cause this thread is confusing, i mean heres what i have to look for so far:
tsi exhaust manifold w/ tsi downpipe
autometer gauges- egt, boost, oil pressure
t3 turbo w/ internal wastegate or b14
turbo xs h-34 bov
GReddy Profec B Spec II Boost Controller
evo 8 stock intercooler
tsi ic piping
12:1 fmu and gsx fuel pump
braided oil lines
if someone could tell me what im missing it would be appriciated
thanks
Old Sep 11, 2004 | 09:57 AM
turbo03oz's Avatar
yea im in the same situation as maxum, you guys confused me on the fuel setup
doesnt the ecu have to be reflashed for stock injectors to run 9 psi? i think that is how rrm does it or wil the safc be what i need to adjust that
ok,,,,, but all i am gonna need is a 12:1 FMU, a 190 GSX fuel pump, and the
apexi s-afc.
Old Sep 11, 2004 | 10:53 AM
maxum17ft's Avatar
i dont think the s-afc does shi+ for our car, prolly be cheaper buying the injectors, than dropping 450 on a piggyback even though it does add more power. there are other posts on here complaining about s-afc's and their similars saying that they dont work for our lancer. i think im just gonna get bigger injectors.
