OK, according to the wiring diagram chart that is posted on this site, the park lights are a green/white and a green/yellow wire at the white plug under the fusebox. Well, I am looking at that plug that is directly under all the fuses and there is no green/white wire, but there is a green/yellow wire. I start looking around and there is a plug furhter down under the kickpanel that does have a green/white wire. Also, that white plug under the fusebox is labeled as saying the white wire is the door trigger/dome light supervision...there are 2 white wires in this plug....hmmmm
Anyway, looking at getting some assistance on what I need to be looking at to finish this alarm install...it's got me wondering...the door lock wires are purple and lt green for lock/unlock, well I see the plug (I'm assuming), but the purple is a small gauge (18 maybe) wire while the lt green is like a 12 gauge...are these the ones I need to be looking at?
Thanks in advance...I usually know what I'm doing, but seeing as how the chart doesn't SEEM to jive with what I have is confusing me more...LOL!
This should help you out.
05 Lancer Evo
12volts white (40A) + ignition harness
Starter black/yellow + ignition harness
Second Starter N/A
Ignition black/white + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/black + ignition harness
Second Accessory blue/white (not required) + ignition harness
Keysense blue ignition harness
Notes: The wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Power Lock purple - driver kick, door harness
Power Unlock lt. green - driver kick, door harness
Lock Motor blue/red 5wi driver kick, door harness
Unlock Motor white 5wi driver kick, door harness
Parking Lights+ green/yel (L), green/wht (R) + white plug bottom of fuse box
Parking Lights- N/A
Hazards white - hazard switch
Turn Signal(L) lt. green or white/blue + driver kick, harness to rear
Turn Signal(R) yellow + driver kick, harness to rear
Reverse Light brown + driver kick, harness to rear
Door Trigger white - white plug bottom of fuse box
Dome Supervision use door trigger wire
Trunk/Hatch Pin green/orange - light in trunk
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm gray - driver kick, door harness
Disarm No Unlock see factory alarm disarm
Tachometer black/yellow or black/green ac either ignition coil
Wait to start N/A
Brake Wire green + brake pedal switch
Parking Brake blue/red - parking brake switch
Horn Trigger blue/red or red - horn switch
Notes: It is blue/red on the standard models and red on the Evolution VIII models.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
05 Lancer Evo
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
yeah, I already have that...that's what I'm talking about...which white plug? The colors in the white plug below the fusebox do not correspond to this chart...
As far as I know the 05 is no diffrent from the 04 and 03 cabin wiring, however since i posted that sheet in this forum i will try to help you as much as i can. My tech sheets show no change in the wiring but I will try to get a hold of an 05 tomorow or soon as i can.
I can also try to help you through it over the phone if you want if you have a multimeter...
Benji
Benji
sounds great...any help would be much appreciated...I do have a fluke. I had in mind maybe workin on the car this weekend sometime and hittin it hard...I've got most of the components (ie, glass breakage sensor, 2way transmitter, brain box, microwave sensor, remote trunk solenoid, LED, override switch, etc) mounted in their respective locations and I've started the wiring. I have a schematic I made up with the relays I need to use and where everything SHOULD go. As I started gettin into this, I noticed some of the wires didn't seem to match with what's on the chart, so I put the rest of the install on the backburner until I can get a resolution on where everything is at before I start slicin-n-dicin.
Thanks again and let me know what you come up with. PM me if you want to coordinate a phone conversation that would be good for both of us...
