High output alternator
Old Jun 9, 2005 | 05:08 PM
lancer02Josh's Avatar
Does anyone have or know where i could get a high output alternator. Also, if you have one where and how much did it cost.. thanks
Old Jun 9, 2005 | 09:59 PM
Lance Dogg's Avatar
only place i got quoted said about 795 bucks...
Old Jun 9, 2005 | 11:59 PM
grubiaco's Avatar
dang! Why do you need one? Is it because you are running a crazy system?
Old Jun 10, 2005 | 08:16 AM
no offense but why does everyone ask why i need one .... obviously its because my amps are drawing too much power...but **** $800 that better come with a blow job thats insane... there is no reason it should be that much....no more than $400
Old Jun 10, 2005 | 09:09 AM
SLVROZ_03's Avatar
Any one with no background in custom systems could really understand what you're tring to do. It is obvious why you want/need one...not enough POWER!!! Wish I could help...maybe one from a Galant/ Outlander/etc. Not really sure, never really researched it in depth. Good luck.
Old Jun 10, 2005 | 09:14 AM
wiretap's Avatar
I've heard of people with other type cars taking it to a shop and having them re-build your alternator so it flows more juice.. there is a shop like 20 miles away from me that does it. They just replace the internal coils and stuff so it pushes more amps.. then you might also have to upgrade some wiring and fuses.
Old Jun 10, 2005 | 09:36 AM
ExcessLancer's Avatar
I have my stock nator in but Yoy could try one from a larger car as stated but also you may want to put a 14.5 volt on instaed and upgrade batteru to 14.5volt
Old Jun 10, 2005 | 10:14 AM
i have a redtop.. got a quote for a mitsu 160 amp one for $700 thats insane.... think an outlander would bolt up and have no electrical prob... the part number he gave me is # 22969 he said its a direct bolt on...
Old Jun 10, 2005 | 10:34 AM
wiretap's Avatar
Amps are trying too much power I hear?? Well, if you don't go with my option or try to find another alternator, why not just have a spare batter or two in the trunk? If you already have this huge system, I guess you aren't worried about weight reduction.. Get a capacitor(s), a spare battery or two, grounding kit, voltage stabilizer, and you should be fine.
Old Jun 10, 2005 | 02:14 PM
caps and extra batteries will not help. its too much to explain.. look it up....alternator is the best and really only option when you are pulling a lot of current. im looking into finding a shop right now. delaware isnt exactly a hot spot for car stuff
Old Jun 10, 2005 | 02:28 PM
logikalliquid's Avatar
http://stores.ebay.com/Iraggi-Altern...Q3amesstQQtZkm
This guy is one of the best respected alternator guys. Look around CarAudio.com or soundillusions.net if you want some references for his work. I don't think he normally lists any mitsu alternators, but if he can't make you one, it can't be done. It also shouldn't be more than $400 for his top of the line alternators.
Old Jun 10, 2005 | 05:21 PM
HobieKopek's Avatar
If the 4g93 has the same alternator, then that guy has alternators for us from 100-180amps. Do a search for "Mirage" in his store.
Old Jun 11, 2005 | 05:20 AM
davids2004's Avatar
Here is some info I got but he says it is for an 04 mits lancer evo. So not sure if they will work exactly the same if we have the same alternator.
90 amp 70 amp idle $155.00
115 amp 80 amp idle $199.00
Alternator comes with 30 day warranty, add One year warranty for $49.00, add
Lifetime warranty & Exchange program for $99.00.
180 amp 90 amp idle $369.00
200 amp 80 amp idle $389.00
Alternator comes with one year warranty, add Lifetime warranty & Exchange
program for $99.00.
his email bret <bretharbison@comcast.net>
Old Jun 11, 2005 | 05:56 AM
SLVROZ_03's Avatar
Exactly, how many amps is our alt push'n anyway? Never really looked into it.
Old Jun 11, 2005 | 07:36 AM
i believe ours is somewhere around 85 max not sure about at idle... those prices are alot better then what ive gotten. who are they from
