central locking on alarm install ?
Old Sep 24, 2005 | 02:40 PM
blackfly's Avatar
hey guys peeled off my alarm install last night with all the wiring diagrams etc, however I could not get the central locking to trigger ? In alll the diagrams etc it shows the light green and purple wires the go from the plug into the door harness loom are the ones to tap into, but they dont seem to triger with my test light or show a 12 volt movement with the multimeter? when you unplug the specific loom plug it stops movement of the drivers door whrn pushing the lock unlock on the button.
I am aware that the lancer has a factory immobliser and central locking, but it appears that my car also has a factory alarm which also sounds the horn after entry ? it also has a 'security fitted' sticker on the back window when i got it. It def has never had an aftermarket alarm installed ? I am in new zealand and we have imported it from japan so it possiably could be a different spec to your guys one?
maybe I need to locate the actual central locking relay and trigger it from there, any thoughts ?
