Rubber gromet
Rubber gromet
About a year or so ago i installed 2 10 inch subs in the tunk. i ran a 4 guage wire from the battery, through the fender, and through the rubber grommet down by the drivers foot. at the time i couldnt get the wire to go through so i popped out the grommet and fished the wire in that way. well a few weeks ago it rained really bad down here, palm beach fl, and i got tons of water through there into my floorboard. i asked the guy if he oculd repair it, assuming he would just cut the wire, it'd be easiest, but no, i looked under and he snipped off the part so i slides on the side
it still hasn't fixed the problem so i was wondering if i could buy a new grommet and if it was at all possible to take the wires out of the grommet and put the stock wires back through? any help is greatly appreciated
lunchb0x
lunchb0x
Originally Posted by gregivq
I had the same problem. Just buy some silicon from a hardware store and glue it all together. The silicon is stretchable so if you would ever want to take it out it's easy.
grommet
Well, find a grommet that fits. try a car audio store, or drill a bigger hole if need be. If you don't put something in the hole to protect the wire, you will eventually have a fire from a short. it will eventually wear through the wire insulation.
well at the moment i have a piece of some sort of tar paper. its a thick piece of what seems to be tar that molds over it, but it doesnt seem to last long enough. i get it from tire places. its sorta like what you use to patch the tire up. but im sure i can get the grommet form the only problem i can see is how to remove the wires and feed them through again
if i'm correct i did the same with my exterior light switch, cept i cut a hole through the middle of the grommet, fed the wires through the hole then used silicone to seal it up. From what i can tell it works fine... But i'm not exactly sure you're talking about same grommet as mines. Mines was eliptical and was about 2-3 inches on the longest diameter...
the hole i am talking about is down by the drivers feet towards the fender. it has many of the wires that lead to the fuse box under the dash i believe and the whole is, as it looks, to be just big enough for what its used for
wire
well, Please tell me you at least put a inline fuse somewhere near the battery on this wire to your amp... If not and it shorts, you will have really big problems, between toxic smoke, and a car fire.. go to any car stereo store they sell grommets to fit the wire size. Do it soon though. you might have to disconnect the wire from engine side, push it through hole, grommet it and pull the wire back out.
