VIPER 791xv HELP!!!!!!
Old Oct 18, 2005 | 09:19 PM
azn6oy's Avatar
i got a VIPER 791xv alarm and iam trying to install in to my lancer but iam afraid of the wiring is going to be incorrect and that it would mess something up... other thing is that wat if ur doing the wiring and u came across a wire which the alarm tell u to connect but the car does have it do u skip it or wat????
HELP PLZ!!!!!!!!!
Old Oct 18, 2005 | 09:22 PM
lookslikeanevo's Avatar
have you ever installed an alarm before? from what ive heard the 791/790 is like one of the hardest installs to do, but i wouldnt know cus i had Circuit install it
Old Oct 18, 2005 | 09:33 PM
azn6oy's Avatar
well no i never did i have seen ppl do it but really never got my hand-on.... i got like the car wiring charts and the alarms instructions and stuff but i duno if my wiring chart is correct or update
Old Oct 18, 2005 | 09:35 PM
ya then i wouldnt do it...you put a lot of risk that way....watching people and actually doing it is something that is a lot harder than you think
Old Oct 18, 2005 | 09:36 PM
azn6oy's Avatar
yeh but i dont want to go out to the shop and spend like 250 to install it where i can take that money to go get something else for the car you kno
Old Oct 18, 2005 | 10:29 PM
logikalliquid's Avatar
Screwing up an alarm system can cause a lot of problems though. They charge that much to install that for a reason; its a few notches above installing a headunit on the difficulty meter.
I hate discouraging the DIY spirt, but that isn't the simplest alarm, and not the one you really wanna try and learn on.
Old Oct 18, 2005 | 10:34 PM
NoTec's Avatar
Yo Boss! take it to a shop and have them do it. I have seen people burn their cars to the ground installin anything from an alarm wrong to an xm radio. If you havent done it before, let someone do it. plus they usually offer a life time warranty on the labor.
Old Oct 18, 2005 | 10:38 PM
exactly...250 is nothing when you fry unknown things that cost a lot more than that to fix...
i used to work at circuit, and helped out a lot in the roadshop, im confortable enough to install a head unit and speakers without a problem. i helped install a few alarms and mobile video...
alarms are not the easiet thing to do if you dont have tech tips(CC roadshops communicate about installs and how things go and where they go) and you havent done a few under your belt...i would say take your $200 and get it installed
Old Oct 18, 2005 | 10:39 PM
2hot2handle's Avatar
HELP PLZ!!!!!!!!!
the VIPER 791 is not a hard alarm to install. its certain cars that makes them hard. first of all, the lancer/EVO is a real easy car to install an alarm on.
Prep the alarm first:
cut all the wires you dont need (theres quite a few) and tape up.
identify/test your wires w/ a volt meter
-heads-up, your doortrigger and power lock/unlock are a negetive (-) pulse
- all your 12v, accessory, ignition, starter wire is easily accessable from your fuse box, just follow where it runs from your steering column.
- your door trigger, power lock/unlock is located at one of the white plugs at the bottom of the fuse box.
- for your breakwire, look at your break light bulb wiring, once you identify it, pull off your side panel trim and tap from there
-if its a manual transmission, just ground the neutral safety switch to a good ground anywhere.
if you use T-Taps it would be a lot faster tapping to.
hope that helps, let me know if you have any other q's
Old Oct 18, 2005 | 10:40 PM
dexterdizzle's Avatar
yeah man dont do it yourself. i just put the pager remote start in my car and it took about 4 hours. Not fun at all. a whole lot of splicing and soldering. YOu are gonna regret it in the end when your car wont start just cuz you put it in wrong. then your gonna have to pay more than regular install price to trouble shoot and get your car running again and the alarm put in. take it to a shop. best buy does em for like 120 bucks.
Old Oct 18, 2005 | 10:42 PM
Hey man if you unplug the actual harness that plugs into the clutch at the top. its two wires i think theyre green and green with yellow stripe it will work fine, greanted you no longer need the clutch to start the car but worked out fine.
Old Oct 18, 2005 | 10:43 PM
NoTec's Avatar
The Best Buys around here do em for 240 bucks, so if you can find one that does it for 120 bucks (assuming your not an employee), JUMP on that deal.
Old Oct 18, 2005 | 10:48 PM
thanks, for reminding me
you WILL need to bypass the clutch in order for the remote start to function if its for a manual trans.
unplugging/bypassing/relay.......however you want to do it.
Old Oct 19, 2005 | 06:27 AM
azn6oy's Avatar
today is my day to install my car alarm haha thanks for the help man... i got the lancer wiring charts and the alarm instructions so it should be ok... wat i seen on the wiring chart for lancers and the stuff htat is on the alarm most of the stuff is not even on the lancers
Old Oct 19, 2005 | 07:54 PM
sadude's Avatar
let us know how it goes...what wires should we not worry about?
what about remote start and where do you place the modules?
how about running the antennae for remotes?
what about LED and horn?
