new system...speaker adapters?
Old Apr 7, 2006 | 01:38 PM
wiscoshowoff02's Avatar
I am currently in the process of getting a new sound system for my car. The speakers i am looking at are Polk db6500 components in the front and Infinity 6012i in the rear deck both of which are 6.5" speakers. i am also going through crutchfield to purchase them. the question is do crutchfield's free speaker adapters/accessories work well with our car's OEM opening? thanks in advance
Old Apr 7, 2006 | 02:04 PM
LancerMarita's Avatar
It seems like Crutchfield sends stuff that works. I got a deck from there, and they sent me everything I needed for installation. Everthing worked well...no problems. I would assume other items are the same? i.e. speakers?
Old Apr 8, 2006 | 08:42 AM
SLVROZ_03's Avatar
One could only guess at this point... But some speakers have an adaptor in the box from the factory. Take my MB Quart components for example, the mid-ranges came with adaptors for OEM 6.5" openings (which always tend to run like 6.75).
Old Apr 8, 2006 | 04:56 PM
saecoes's Avatar
from my knowledge infinity 6 1/2's come with 6 3/4 adapters, which will fit perfectly for our lancer. what i did personally was drilled holes in the steel of my door frame to mount the fronts. i believe the same will work well for the rears too.
Old Apr 8, 2006 | 05:21 PM
diamondstar03's Avatar
You will receive the correct speaker adapters and the appropriate wiring harnesses if you get the speakers from Crutchfield. I am a technical advisor for crutchfield and we always give you everything you need.
Old Apr 8, 2006 | 05:24 PM
142SAC656 is the bracket you will get and 12071035 is the part number for the wiring adapters. I would just put the crossovers in the doors and seal them up inside a bag with a dab of silicone to attach them and prevent them from moving around.
