stereo problem
Old Jul 30, 2006 | 12:48 PM
salty1331's Avatar
stereo problem
I just switched out my stock stereo with a pioneer headunit, mtx amp and pioneer subs. I have checked all the wiring twice and its all fine...the problem is whenever I accelerate from lower rpms, the head unit stops sending sound to all the speakers, except for the sub. anyobody know whats wrong? All the speakers in the car are stock. Also when this happens I unplug the wiring harness and plug it back in, and if I do it fast enough the unit retains its memory and it will put sound to all the speakers again. anyone know what the problem could be?
its a 2002 oz rally
Old Jul 30, 2006 | 12:55 PM
Bigjoeski05's Avatar
Wow thats really werid
Old Jul 30, 2006 | 06:50 PM
Grey_Fox's Avatar
Did you check the fuses too?
Old Jul 30, 2006 | 06:58 PM
bene's Avatar
haha uhh... the only thing i can think of is the HU but i couldnt tell u whats happening
if your sub is still working then your HU is still functioning then it is your speaker output, so
a malfunctioning HU? thats all i could tell you
Old Jul 30, 2006 | 07:09 PM
Evocore's Avatar
pioneer headunit + STOCK speaker= not good
pioneer headunit + aftermarket speaker = Excellect
Old Jul 30, 2006 | 10:07 PM
mscc04's Avatar
Is there a stock amp in your car? This could intefer w/ the speakers and not the subs if it was not bypassed. The HU's built in amp would probably be more powerful than the stock amp which could be a problem. But I'm not sure....just a guess.
Old Jul 30, 2006 | 10:12 PM
housedj's Avatar
how did u ground the deck?
Old Jul 30, 2006 | 10:16 PM
lanport's Avatar
Ive got a alpine 9354L hooked up to the stock speakers and they
they sound pretty good, but none the less i want better so im going to upgrade my speakers to all infinity.
Old Jul 30, 2006 | 10:21 PM
mscc04's Avatar
Getting an amp is usually more important than replacing the speakers.
Old Jul 30, 2006 | 10:23 PM
mscc04's Avatar
If it was a grounding issue I would think that the sub would cut out the same as the speakers.
Old Jul 30, 2006 | 10:26 PM
housedj's Avatar
have u tried testing all your connections with a multimeter???
Old Jul 30, 2006 | 10:30 PM
bene's Avatar
yeah, cept stock speakers suck... so you get both but that is true ^^
Old Jul 30, 2006 | 10:39 PM
mscc04's Avatar
i agree with that as well
Old Jul 31, 2006 | 05:05 AM
Lunchb0x's Avatar
when u put the aftermarket speakers in, did u use a harness adapter or did u splice the wires, more than likely either one wire got switched or you didnt crimp the connection all the way. might want to look into that option
Old Jul 31, 2006 | 06:42 AM
salty1331's Avatar
the head unit wasnt brand new so there is a chance it could be bad, it came out of my car that I had previous to the oz, which was sitting in my yard for prolly 6 months before I took it out and put it in the oz. I will go and check all the connections between the harness adapter and the head unit though. and the stereo is grounded with the rest of the stereo stuff behind where the deck goes. the fuses are good too, so I have no idea. Im definately not ruling out that the head unit is bad, Ill remake up all the connections and see if it still does it tomorrow sometime, thanks a lot for all your input though, I appreciate it
