Need Help From All Car Installers!
Old Aug 5, 2006 | 11:53 AM
army685's Avatar
hey guys i need some of your advice from all you car installers out there i just bought a pioneer avic n3 and i was wondering if there is a bypass that can be done i can watch dvds while im driving???? ive heard rumors that it can be done just wanted to hear your info and opinions thanks alot
Old Aug 5, 2006 | 03:06 PM
army685's Avatar
any1 out there have any input on this? i really need some assitance and opinions!
Old Aug 5, 2006 | 05:35 PM
sykou's Avatar
Instead of connecting the wire to your e-brake sensor wire. Just connect it to a on-off switch. I believe the wiring goes (Sensor-Wire)---(ON/OFF Switch Positive)---(Switch Ground to Vehicle Ground). Got to push the switch on on then off to trick the dvd player. Depending on what position the switch is in it may be from off to on or on to off.
Old Aug 5, 2006 | 08:36 PM
kmcconn9's Avatar
/\ that will not work as the n2 and n3 are internally hooked up to a gyro sensor which will cut the video when the car goes over 5mph...
The switch will work until you move and then bye bye video..
You can run the video out into the rear view camera input and that will gety the video up...
I know how to bypass the n2 by putting a piece of solder between two contacts on the bottom of the unit...but I dont know if the n3 has this or not...
Old Aug 6, 2006 | 04:11 AM
army685's Avatar
this is what some people have been telling me that you have to open the brain box on the avic n3 and solder something but i am having second thoughts about that! because something could go wrong, the shop that i might take it to says they have done two already but it still makes you think if they **** up then there goes my unit! i was wondering if there might be another way but thanks for the input guys anymore suggestions out there???
Old Aug 9, 2006 | 10:59 AM
OZLancer1's Avatar
Yup, you're pretty much screwed on watching video on the main screen while driving with the n3. Only way to take care of it is to open it up and internally modify it. Which I would definitely not do. I have my pioneer avh-p6400cd head unit hooked up so that I can watch dvd's while I'm driving and I hardly ever do it. Only time I watch tv is at car shows and then the car's stopped anyway. Plus, if you want your passengers to watch anything, it should be done through other screens anyway since it's kind of hard for rear seat passengers to see the head unit from the back. Plus, any video that is visible to the driver while in motion is illegal. I've always thought that was a stupid safety feature and that if I want to drive while video plays on my head unit, I should be able to. But I've caught myself a few times looking at what's onscreen and all it takes is a split second for you to look away and then run into something or someone. So maybe you should just be happy with your kickass N3 the way it is. Or if you really want to be able to watch videos while driving, you could sell it and get a different head unit that can more easily be bypassed.
Old Aug 9, 2006 | 04:27 PM
army685's Avatar
hey guys thanks for the input but ive been doing alot of research and from what people say all you have to do is connect the wire to your e-brake and there is a sticker on the n3 unit and if you feel it off underneath it theres a switch you just flip the switch and you will be able to watch videos no problem while in motion.
Old Aug 11, 2006 | 05:08 AM
OZLancer1's Avatar
Hmmmm, I can't say that I've ever heard of that. Also, if you hook the wire to the ebrake, you won't be able to watch videos unless the ebrake is pulled. My pioneer head unit uses the ebrake wire as a safety feature and all you have to do is connect it to any good ground source and it will enable video while moving. The unit thinks that you have your ebrake pulled. I'm not sure, but if there is a switch on the N3, I bet it only disables the internal gyro sensor and you will still probably need to ground the ebrake wire somewhere in order to watch video while in motion. Although I have to say, I have friends who are car audio installers and they didn't even know there was a switch to disable the gyro sensor. But hey, if it's there, use it!
Old Aug 14, 2006 | 08:09 PM
army685's Avatar
hey guys a lil update there is a switch to do a bypass on the avic N3 works like a charm and if you want more info on it heres the websight www.avic411.com check it out for all you pioneer users! will pst pics when i have the time
Old Aug 14, 2006 | 08:17 PM
SaOrlando's Avatar
there are ways.....
i had a customer just ground his and it worked.....others have not
the old solder thing is close......same spot, now there is a void sticker you have to pull up
go to avic411.com there are plenty of answers them
DecBro
Apr 15, 2017 12:09 PM
PHILLY EVO
Oct 7, 2016 05:19 PM
ElectrIX Blue
Oct 5, 2016 11:54 AM
hearnoevo
Dec 9, 2015 01:25 PM
psychlancer
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 26, 2006 09:34 PM
