anyone have this porb with kenwood head unit?
600w amp Kenwood its like a KAC-729s or something
here is the link to what amp i got..
http://www.kenwoodusa.com/product/pr...&productId=713
what exactly is happening? be very specific.
first guess would be something to the effect of an overload relay shutting off the amp. if the amp gets too hot and overpowered, it probably shuts off to protect itself. this means that you don't have it properly ventilated, are running too much power to it for too long a time, and are causing too much strain. sounds like the amp is shutting off because of overheating, if you were giving it too much juice it would blow a fuse which i guess isn't happening.
give specific examples of what is happening, and exactly how your system is set up. you said you have multiple amps, do you have a power distribution block? are you running the proper gauge ground wires? are the ground wires kept under 18"? are the ground contacts clean?
[i]NOTE: i did not install this equipment i just bought it... [/B]
Maybe this time they can get it right.
Also if you dont have a cap... get one. Also make sure you have enough air space between the amp and any other thing so it can keep cool. Quite often an amp will get hot/shut off,and or blow a fuse.
anybody else?
ohfourLancer
12
Mar 30, 2007 07:15 AM
lancerfreak311
45
Mar 23, 2007 11:46 PM
drewblueeye
Oct 19, 2006 05:05 PM
