Polk DB650
Old Feb 11, 2007 | 12:10 PM
superfly78209's Avatar
Polk DB650
These speakers seem like the very best bang for the buck. But the crutchfield don't think they would fit. the Top-mount Depth is 2 inches. Does the seem like anything that would conflict with our stock grills and everything? it's a 6 1/2 and the polk DB6500's (the component version) fits fine for some reason and it's pretty much the same thing except a bit taller. The sales person said that the bottom depth was fine and the top was too much so the speaker would be "crushed." what do you guys think? thanks
Old Feb 11, 2007 | 08:55 PM
bump
Old Feb 12, 2007 | 03:59 AM
SXTNYNR's Avatar
You could always fabricate a plastic spacer to lift the stock grill. I think they are telling you that with full excursion of the speaker, it would hit some of the grill. Unless you like the sound of rattling speakers, and like the risk of tearing cones, I'd suggest that increading the height of the grill may be your only solution. Hope that helps.
Old Feb 12, 2007 | 08:23 AM
Hey
What if I just took out the grills. Are the front door grills connected to the door panel or can they come off? I bet that only the tweeter sticks out. I could cut a hole or a semicircle in the grill to see if the tweeter will stay in. These polks seem real nice. Any other ideas on how I could make it work? I wonder what the stock upper mount depth is? Anyone know? If it's like 1/2 inch I can make it work probably.
Old Feb 12, 2007 | 08:26 AM
and if I don't get the polks can anyone tell me what speakers to get that have clear bass. Not like hardhitting bass but just something decent. and good mids and highs. Those polks got awesome reviews that I'm not seeing anywhere else.
Old Feb 12, 2007 | 08:49 AM
BoostWhore's Avatar
they wont hit u will need some type of a bracket to adapt them to the factory mounting points polks run a little small. There pretty good speakers though
Old Feb 12, 2007 | 09:07 AM
johannes's Avatar
I installed them in my car. I just closed up the openings a bit in the rear deck and then drilled some new holes. You can just bend the lip of the stock openings up to fill in the gaps for the slighlty smaller Polks. If you feel comfortable with a minor bit of install work, they are great. I didn't use any brackets.
They sound decent, but need a bit more power than the stock speakers. I have the Evo SSL package (w/amp), and that was adequate.
Old Feb 13, 2007 | 12:16 PM
Basically I'm back to step one. I know what headunit I'm going to get. It's a kenwood that pushes 22W x 4 rms. I want good speakers that come with all the necessary hardware to install them in the doors and the rear deck. I'm going to get them for cheap on ebay so all I'm going to get is the retail package. None of the goodies that crutchfield sends. So does have any good 6.5's or 6.75's that mount perfectly with all the stock hardware and have clear/clean bass and great mids to highs. I'm not talkin about thumpin bass but the bass has to be there at least. Thanks
Old Feb 13, 2007 | 03:51 PM
bene's Avatar
for the door speakers, if your not going to amp them, a low RMS 6 1/2 speaker would be awesome, not all 6 1/2s have the mounting problem
Old Feb 13, 2007 | 03:54 PM
GPTourer's Avatar
I had them in my Galant and was runnign them off an Alpine HU. 9835 I think it was. They sounded very good. I think they are worth the modification to get them in the car if all it takes is a spacer.
Old Feb 13, 2007 | 06:12 PM
does anyone know which 6.5's don't need any modification. I know how to install a system but as far as modifying things go, I'm pretty clueless. Anyone get any good speakers that came with all the parts you needed to install them in our lancer. What about the 7" kickers? thanks
Old Feb 13, 2007 | 06:42 PM
bene's Avatar
i have 6.5 kickers in my door and i just bought an adapter bracket for $5 at my local audio store and they screwed right in... they sound great people always ask me if i have a sub or not i have the KS series which is 75 watt RMS which sounds good and has good bass with just a HU and sound amazing amped... the DS series has a 60 watt RMS so you will be able to get more out of them, the other series are 100 watt rms so i wouldnt recommend them
Old Feb 13, 2007 | 08:33 PM
so basically i can buy any 6.5 and as long as I go to a local audio store I should be able to spend $5 and get a speaker bracket. what about the kenwood 7" will those fit w/out a speaker bracket?
TpArK
31
Apr 14, 2012 12:32 PM
ralliartyz250
Aug 8, 2011 08:04 PM
ThndrGryLs
10
Jul 27, 2010 01:04 AM
UCB
Jul 30, 2006 09:43 AM
EvoNick
May 21, 2003 08:16 AM
