bass question
Old Mar 12, 2007 | 09:16 PM
deontae's Avatar
bass question
for every one that has a lancer out there with a system what is the max that the lancer can take without the lights and **** dimming
Old Mar 12, 2007 | 09:22 PM
evovin's Avatar
I used to have a lancer...i put a 2nd battery yellow top at the back and 1 farad capacitor and it never dimmed again!
Old Mar 13, 2007 | 12:51 PM
Never Satisfied's Avatar
My lights dimmed from the factory anytime that I let the car idle down a little bit. So, this question maybe a bit pointless... but just to humor the thread...
I have an Alpine MRD-M605 sub amp rated at 600 watts into 2 ohms, so by all standards on here, until I get a chance to test and calculate... I'm running 500 watts and only start to get light flicker when I turn the stereo all the way up and have the bass turned up from the normal setting.
Old Mar 13, 2007 | 01:07 PM
SnapDragun's Avatar
Replace the stock Batt with an Optima Red Top or Yellow Top and then replace the stock alternator with a beefier one. Other solution is a voltage/amps regulator/stabilizer. Dimming happens in automobiles because volts & amps are being drawn in large amounts faster that they are being replaced - no stabilization.
Old Mar 13, 2007 | 01:15 PM
Nissaka's Avatar
Get a good sized capacitor and you will be able to go high.
Blynitha
Apr 4, 2017 01:19 AM
tanabe
41
Nov 28, 2010 05:33 PM
RalliArtI4
Northeast Region
10
Jul 28, 2004 11:05 AM
jlanceroz
Canadian Forum
17
Oct 7, 2002 09:06 AM
pearlwhiteoz
19
Oct 1, 2002 12:50 AM
