please help installing system on evo
Old Jun 10, 2003 | 03:40 AM
EvolutionEight's Avatar
i need help installling front speakers
i have a pioneer in dash tv screen that i pulled out from my civic that i am gonna put in the evo, i think i could install that no problem..but when it comes to speakers and sub..i am totally a newbie.. i bought mb quart dsd 216 6.5 compoent for the front and leave the stockie in the back.... i dont know how to hook up the tweeters and the mids...can anybody give me a guide? i read about something like a plug and play harness for the fronts, do they only work on coaxials or they have some for compoent? if i could aviod cutting the stock plugs would be great... i need help on how to hook up the tweeter and the speakers to the cross over and what setting should u use on the crossover? i am not planning to hook up an amp for the speakers, just run it off the module that i got avc7000R, any help would be appericated, thanx in advance..
Braniff
Old Jun 10, 2003 | 02:02 PM
Higgity Hank's Avatar
Normally, I'd tell you to search... but I'm feeling extra nice.
https://www.evolutionm.net/forums/sh...threadid=26007
That thread will give you a step by step on taking the doors apart
As for quick connects, I wouldn't bother. Hell, I wouldn't even bother with the stock wiring. Just run a new set of wires through the boot from the cabin into the door. Then, splice them directly into your harness connector.
I'd still suggest an amp though... your components will sound much better using a seperate amp than they ever would using a built in HU amp.
Old Jun 11, 2003 | 09:39 AM
that you for your help, i actually saw that post before i asked..but i also wanted to know how to connect the tweeter and the mids to the cross over,cause i havent done it before..but i think i could search on google or ask friends..but i do have one last question ..is 1inch tweeter gonna fit where the stock tweeter is? will it mount up perfectly? thanx once again
Old Jun 11, 2003 | 02:49 PM
No idea about the mounting... I drive an OZ. No tweets for me (not till my Morel 39's come in anyhoo) but the XO is usually very clearly labled.
With the wiring in the car, you'd do much better to run new wires. Just take the RF+ and RF- from the HU, plug them into the XO where it says Input + & -. Then on the outputs, the + of the woofer goes to the Woofer + on the XO... and so on. The only thing you might question is the Tweeter. It may have a few places in the XO where it can plug in. One will be straight out, the other may be -3 or -6dB. Use the straight one first, if the tweeters are too harsh, cut it down a few dB. Component speakers are very straightforward (till you start assembling your own sets)
Old Jun 11, 2003 | 02:52 PM
Nero's Avatar
The only thing I would wonder is not if they will fit but if they will sit flush....?
Old Jun 11, 2003 | 06:56 PM
Sitting flush is what they made fiberglass for
Old Jun 13, 2003 | 06:49 PM
Nero's Avatar
well the either the es or ls pillar mounts for the tweets do not sit flush stock. i wouldent want to go thru all that hassle, but thats just me.
Adam Thompson
Oct 11, 2016 06:07 AM
Weathergeek
Mar 16, 2015 09:43 AM
hexaggram
Feb 28, 2015 03:56 PM
ZK
May 20, 2010 11:08 PM
LancerEVOVIIISD
48
Jan 13, 2007 12:43 PM
