System Won't work
Old May 27, 2007 | 04:40 PM
sykou's Avatar
the one that is labeled "-" or GND. Take a picture of your amp conections and i'll popint it out if you still don know
Old May 27, 2007 | 07:01 PM
Never Satisfied's Avatar
If everything powers on correctly (fan, light, etc), then the ground is probably not going to be the problem. The ground problem would cause the amp to come on and shut back down, play quietly and get hot quickly, or not even turn on at all
Here's a really stupid error, that I have actually seen people have... just checking to make sure. Is the fader on the CD player run all the way to the front speakers?
Also, make sure you check the connections at rear speaker wires to the (I'm assuming) line-level converter. Might just be a bad connection.
If you have an IPod or similar, you could try using a cable that plugs into the RCA connections on the amp and the headphone jack on the MP3 player. Turn the car on and see if you get sound. At least that will help you narrow down the area of the problem without having to fully swap the amp with a friends.
Old May 28, 2007 | 03:24 AM
sykou's Avatar
^ fader, high low inverter. Good thinking.
Arxylis
Apr 10, 2012 06:36 AM
bboy_RES
10
Dec 16, 2008 07:39 PM
Racer1
Feb 28, 2005 08:32 PM
B Pars
25
Jan 19, 2005 04:31 AM
nrgaura
Lancer Troubleshooting
Oct 21, 2004 05:28 PM
