How to install and power 2 amps?
Old Dec 27, 2007 | 01:20 PM
longrun85's Avatar
I have a 600W amp on 2 10" subs now and I want power my other amp for my other speakers which is also 600W. Can someone help me with the installation process and what else I need to buy.
I just bought a 1.0 capacitor also! Need help with that installation also.
Old Dec 27, 2007 | 03:58 PM
robyn402's Avatar
this is what i did... basically all you need to do is split your power and remote turn on lines by;
-throwing in a fused power distrobution block, and making sure you have the proper amp rated fuses for each line.
-and tossing in a 3 way solderless connector on your remote turn on lead so you have you main remote line going into the connector and one line going to each amp
i'd strongly suggest running at least 4 gauge wire to the distrobution block
pretty simple really, its like splitting you cable at home....
Old Dec 27, 2007 | 04:05 PM
Drifting Away's Avatar
Kicker sells a 2 amp wire kit with everything you need...
Onlinecarstereo.com has a cheap price for the one im using
