Amp Wiring
Old Jul 31, 2003 | 12:32 PM
KillaSweep's Avatar
Amp Wiring
Hey there...I am installing an amp right now in my car and have forgotten whether it matter if i run the RCA cables and 4 gauge power cable parallel to each other down the side of the car. Does this cause interference? I can't remember...Thanks!!
Old Jul 31, 2003 | 12:36 PM
Higgity Hank's Avatar
Run them as far from each other as possible.
Old Jul 31, 2003 | 12:54 PM
KillaSweep's Avatar
Alrighty I will.....i'll just run the remote wire and RCA's down the opposite door sill. Thanks for the help!
Old Jul 31, 2003 | 01:09 PM
lancer r us's Avatar
does the size of the red power cord. matter?what i mean is are there different sizes?like for different kind of amp. ive never done this but ive seen guys install thier amp them self.
Old Jul 31, 2003 | 01:11 PM
SICKdimension's Avatar
for how much power the amp needs. i have 10 gauge, which is the lowest, but if you had a really powerful amp, you would get lower, up to 0 gauge.
Old Jul 31, 2003 | 01:19 PM
well cause what im planning to do is this.
i currently have a head unit right now with a 200watt 2 channel(bridge to one sub) amp. its pretty lame. but when i saw the guys install my stuff. they putt the rca.(red and white cable) and a red power cord thats connected to the battery together. im planning to just replace my 200watt amp to a 800 or 600 watt amp with the original wires that the installer installed my 200watt amp.
can i do a complete swap or i also need a new power cord.(mainly cause ill be using a more powerfull amp?)
Old Jul 31, 2003 | 01:32 PM
The Gig's Avatar
You need new power cable to run the higher powered amp and you need to seperate the power cable from the RCA's to eliminate any interferance or engine noise whistling through your speakers
Old Jul 31, 2003 | 01:34 PM
so what kinna power cord is out there? so what should if im going to go with the 800watt?
Old Jul 31, 2003 | 01:35 PM
platinum drew's Avatar
actually it depends on how large your cable is, and you probably don't need a new one if it was 10 gauge and you're only moving up to 600w...for 800w I might move up to an 8 gauge...
Old Jul 31, 2003 | 01:41 PM
actualy 200w to a 800w.hehhheheheh i found a really nice amp at ebay that why.heheheheeh
shoot i dont even know what kina gauge i have! is it labbled on the cord?
Old Jul 31, 2003 | 01:56 PM
ewoevo's Avatar
Assuming you are mounting the amp in the trunk, I'd go with 4 gauge power cable, if the amp is a good quality, honestly rated amp. My reasoning is the distance the power has to travel compared to the cross section of the cable. I can't remember the formula for determining which size cable to use, but for this length, go with 4 gauge. It's better to have too big a wire in this case, rather than too small. That way you're not starving the amp for power at higher levels. Just my 2 cents.
Old Jul 31, 2003 | 02:05 PM
so a 4 guage will do the trick. hmm ok thanks. im thingking about relocating my amp under my seat. but i think ill work out.
Old Jul 31, 2003 | 02:14 PM
KillaSweep's Avatar
Get a 4 guage power cable. You can pick up a 4 gauge amp kit with all the wires and fitting and fuses that you would need for like $22. They are cheap, but very high quality...I have actually installed 3 amp using them and have found nothing better. Have fun! I just installed all the wiring on my amp today...came out real well! Just make sure you run the RCA cable down the opposite side of the car as your power cable...not even a triple shielded RCA cable would be able to block all the electrical noise from a 4 guage power cable...good luck!
Old Jul 31, 2003 | 02:15 PM
KillaSweep's Avatar
I'm an idiot...i talked about the cheap amp kit and didn't say where to get it....one word....EBAY!
Old Jul 31, 2003 | 02:17 PM
oh by the way.i have 2 10"mtx sub. do i need a special speaker wires also for optimized performance
