Running power wire
Old Apr 27, 2008 | 08:31 PM
Lucas03ES's Avatar
Running power wire
I've tried to research running power wires through my car (03 ES Automatic). I found the grommit on the far left side of my engine bay, but I don't feel too safe draping it across the entire engine bay. I could run it through the fender but I read that the door could pinch a wire. I saw a couple people talking about putting it through where the clutch lines would go. I looked under my drivers side by the firewall and I saw a little Hole in the foam and a huge hole in the foam, but no actual hole in the firewall. Would I have to drill (I don't mind doing that) a new hole?
Also, I have a stinger 150 amp fuse that is sorta large, anyone know of a good spot to mount it? Thanks for the help
Old Apr 28, 2008 | 10:25 AM
cdx280's Avatar
Yeah, just drill through it. Now that you've seen there is space on both sides, you know it is clear. no big deal.
