Need Help Asap
Old Sep 12, 2008 | 05:03 PM
nawgee's Avatar
Need Help Asap
i had a problem with my system cutting off and then back on. ok so i finally fixed the problem and it was because apparently i closed my door to hard and the speaker was knocked loose and i must've forgotten to tighten it before. because it was making contact with my chassis, it caused the music to zone in and out. ok well anyway i fixed that and now got smacked in the forehead with a new problem....
I got rid of the cap and have my 500/1 mono amp by itself. But the weird thing is my sub wont actually come on!!! i know its connected because i go up close to it and can hear a low static noise. im going to be going out with my friends pretty soon and want music back up =(
(hello all, i have a problem. . .im addicted to bass and i can't enjoy my friday night cruising without my w7 punching me in the chest) =(
Old Sep 12, 2008 | 06:02 PM
doctorjon's Avatar
Sorry to hear that, i wouldn't be able to help you unless i know further details on your set-up.
Old Sep 12, 2008 | 06:05 PM
Eviil8's Avatar
do you possibly have the positive and negative wires reversed?? did you try that?
Old Sep 12, 2008 | 10:02 PM
hugador's Avatar
Check your amp if it's on. Check amp fuse. Maybe when removing the cap, wires might have touch thus blowing your fuses. If it looks fine try connecting another speaker to the amp just to see it its not the woofer. And if the other speaker don't play then the problem may be the amp or the way it is connected. recheck your system wiring.
Old Sep 16, 2008 | 12:12 AM
cmr076's Avatar
is the amp on? i am assuming when you say 500/1 you mean jl? are any other lights on (protection, low impedance?) what sub are you running? and what impedance do you have it wired to??
nmilsaps
Apr 2, 2012 05:31 AM
DMuhny
Aug 18, 2011 02:27 PM
LancerFreak
16
Sep 6, 2002 09:40 PM
