RCA outputs in the 09 lancer gts sportback
Old May 5, 2009 | 11:41 AM
sportback09's Avatar
hi all new to this forum, i just got a sportback gts, i wanna install subwoofer and amp since i got one laying around from my old car... could i use those rcas to connect to the amp instead of splicing the speaker wires? the rcas are located underneith the climate controles, right into the storage slot or whatever you wanna call it... where would i wire up the remote wire?
Old May 5, 2009 | 12:07 PM
lancer0220's Avatar
those RCA jacks under the AC climate controls are INPUTS not outputs so that wont work.
just splice the wires to the rear speakers and attach an amp
Old May 5, 2009 | 02:41 PM
yitzac1990's Avatar
and you need a line output converter
Old May 5, 2009 | 06:55 PM
so i need a line output converter if i want to use the stock deck? where does it connect to? the rca inputs?
where would the remote wire go to? a fuse? this wire splicing thing seems kinda dangerous iunno if i wanna mess with it..
Old May 5, 2009 | 07:44 PM
yitzac1990's Avatar
go to a car audio shop lol
Old May 6, 2009 | 09:35 AM
MujahidMD's Avatar
Got any pics of your sportback? I havent seen one on the street yet.
Old May 6, 2009 | 04:27 PM
i dont trust the shops... i geuss ill try splicing the wire, torquise and yellow thicker one... can someone confirm that this is correct? i dont want to end up blowing up my car...
also wouldnt the bass equalizer not work? well i geuss it would work a little bit?
can someone tell me how to do the remote wire? do i connect it to the fuse im geussing? what will i need to get in order to connect the wire to the fuse? or do i simply jus take out the fuse, put wire in fuse slot and put fuse back in?
and for the pic ill try to get one up when i have time, maybe a pic of my system when its done to i got a kicker i wanna put in there, should sound great in a hatchback cant wait!!
Old May 6, 2009 | 07:34 PM
yitzac1990's Avatar
lol you dont trust the shops??? hmmm ok well anyways what bass equalizer are you talking about? for he remote just use the cig lighter fuse, you can get an add a fuse adapter from auto zone or something or just put the wire in like you said.
Heebs 09gts
May 31, 2016 08:24 AM
akride907
Jan 9, 2016 03:29 AM
cij911
17
Jun 24, 2009 08:23 PM
Xearo
Apr 14, 2009 02:22 PM
sicx13
Sep 6, 2003 08:15 PM
