installing PS2 into car
Old Oct 13, 2003 | 11:55 AM
DANERS_03's Avatar
hey~
i was curious if anyone tried installing PS2 into their lancer. if you did i need ur help. could u list out steps and things i need to do the complete process? thanks a bunch
Old Oct 13, 2003 | 12:06 PM
Alchemist's Avatar
Go to parts store/ GI Joes and buy power inverter. Bigger is better. Install inverter (My 200W inverter plugs into the cigarette lighter). Plug in PS2 and monitor. Play. Try to beat me at GranTurismo3
You may want to find a place to hide your inverter, but I just leave mine laying up against the center console on the passenger's side.
Have fun- don't play while driving and don't drive like you're playing!!
Old Oct 13, 2003 | 12:12 PM
DANERS_03's Avatar
i molded that hole section (cubbie hole, coin tray and cig. lighter) all together with fiberglass. is there another way that can hook this up?
Old Oct 13, 2003 | 12:36 PM
mikesevo8's Avatar
Installed one in the Evo. Can't tell you if the clearances under the seats, etc. are the same.
PS2 is under the drivers seat, CD tray facing forward. The tray slides out cleanly, no obstructions.
The invertor ( from Radio Shack ) is under the passengers seat, along with my Alpine systems control module. I just plug the invertor into the CLighter when needed.
I have ICEd up the Evo fairly well. I have the following:
Alpine IVA-C801 multimedia system.
Alpine MRV-F340 and MRD-M300 amps.
Infinity Kappa 60.5 - front
Infinity Kappa 63.5 - back
Infinity Kappa Perfect 10.1 Subs.
All that, along with the PS2.
Went for SQL not SPL...and got what I was looking for.
GT3. Shoot, you can play it in my car. Driving the Evo in the game while riding in an Evo on the street, it blows your mind.
And before anyone asks, not, I don't play and drive...I leave that to the passengers. Mostly, the playstation is used at the car shows. I play a saved replay of the Evo running the Rome endurance race. In yellow, of course, just like mine...
Old Oct 13, 2003 | 12:42 PM
DANERS_03's Avatar
again~
i don't have the cig. lighter accessable anymore is there any other way that i can hook this up?
Old Oct 13, 2003 | 12:57 PM
Guru_Del's Avatar
you can hard wire the inverter to your battery. infact for inverters over 200 watts that is recommended.
Old Oct 13, 2003 | 01:17 PM
DANERS_03's Avatar
how much will one of these "inveters" run?
Old Oct 13, 2003 | 01:38 PM
mikesevo8's Avatar
Originally posted by DANERS_03
again~
Sorry...I missed that.
Yea, you are going to have to grab the 12v from somewhere under the dash and run a wire out under the center console.
You can grab the ground most anywhere.
I suggest at the ignition switch wires. You can use a variety of methods to figure out which wire is powered only when the key is turned on. That way the invertor won't draw power with the car off. I know, common sense...
As for cost, if I remember mine was around $25. I think it was a 150W model.
Old Oct 13, 2003 | 01:49 PM
Alchemist's Avatar
you can inline the inverter using the wires that USED to be for your cigarette lighter The benefit is that you will only have power with the key on. You can still take your console apart, right?
Other constant 12V sources with just the power on: That stupid clock, headunit. . . you could always run it off of the battery/alt using a switch like aftermarket fog lights do (make some long wires with ring terminals and wire into the passenger cabin).
Good luck dude
Old Oct 13, 2003 | 02:01 PM
mikesevo8's Avatar
I suggested the ignition wires because the invertor is going to draw about 10A of 12v power for
every 100W of the 115v side you use.
Thats 10A x 12V ( 120W ) x 80% efficiency factor ( if you are lucky ) = 100W.
That's less than 1A at 115v BTW, and a PS2 will draw more.
You will want a 150W minimum.
Just looked under the seat - I have a 160W unit by Jensen. Seems to be the trick.
The point is, stay clear of the smaller guage wires; they may get a little toasty...
Old Oct 13, 2003 | 06:05 PM
DANERS_03's Avatar
thanks for all of the help fellas! it was greatly appreciated. if i run into any kinds of trouble i'll try to reach u. thanks again!
Old Oct 17, 2003 | 07:13 AM
HobieKopek's Avatar
Read the sticky in the how to/install forum. Moving.
Old Oct 17, 2003 | 03:08 PM
jerzepnoy's Avatar
i also have a PS2 for my car and i hate using the DC charger. will i run into any problems if i have the PS2 and Tv on at the same time for about an hour or something?
jfvhpilot
21
Feb 13, 2012 02:50 AM
X1nicelancerX
Jan 1, 2008 03:41 PM
timdog4life
12
Jun 20, 2005 01:29 PM
t-dotlancer
Apr 24, 2003 10:38 AM
super__rob
Mar 26, 2003 10:51 PM
