need help on new system
Old Nov 30, 2009 | 08:47 PM
  #31
yitzac1990's Avatar
yeah they can be separate grounds. also, make sure your radio has outputs for sub, front, and rear...all 3
Old Dec 1, 2009 | 07:21 AM
  #32
lancerguy0208's Avatar
OK. And I'm a little confused on how the speakers wire to the amp and the head unit. Because I wanna upgrade from the factory speaker wires cause its damaged in some places, so where exactly do they all hook up to? I dont know if I should just run the wires exactly how they are now that an amp will be in the equation. Well I just looked at my haed unit and I dont see 6 RCA jacks. I just see two, SW REAR L and R, which my current amp is plugged into. What does this mean? Is there a chance I looked past something?
Old Dec 1, 2009 | 05:20 PM
  #33
yitzac1990's Avatar
lol it means:
1. new radio with 6 channels of RCAs
OR
2. use a 4-channel line output converter, but the quality will be reduced a bit.
once you have the amp where you want it and all, you run the speaker wires right from the amplifier directly to each speaker, even going through each boot between the door and body of the car.
Old Dec 1, 2009 | 08:43 PM
  #34
cdx280's Avatar
The BEST option that yitzac1990 mentioned is to replace the radio with one that has 3 RCA pre-outs. This will give you fade and balance control as well as a separate sub control. In general, radios that have 3 rca preouts tend to be better than those that don't (not always, a lot depends on the brand).
The 4 channel LOC will work, but assuming you have a 4 channel amp it might have high-level inputs. This will let you you run your speaker signal from the wiring harness out of the back of the radio straight into the amplifier without using RCAs (this is only for front/rear - not sub). In this case the only rcas used would be for the subs. The benefit to this compared to the line output converter is less signal loss as you are reducing the number of components in the system.
Another option is to use Y-adapters for the 4 channel. This can either be done by putting the adapters right at the radio and running two pairs of rcas back to the amp, or you can one run pair of rcas from the radio back and split them at the amp. I would recommend the second. If you use y-adapters, then you will only have fade OR balance, not both. Which one you want is up to you. I would recommend that you still be able to balance cuz you can keep stereo sound. Also, when you are tuning the system you can adjust the gain accordingly for the front and rear speakers to get the staging right.
Really, what you need to do is figure out how much $ you are willing to spend all said and done, and then you can work within that budget to get the best solution you can afford.
Good Luck!
Old Dec 1, 2009 | 09:27 PM
  #35
yitzac1990's Avatar
this is the BEST advice you can give anyone on ANY project for ANYTHING!!!
Old Dec 2, 2009 | 11:12 AM
  #36
My amp does have high level inputs. Does that mean I can hook up the amp without the need for the four RCAs on that amp, and then I just use the two RCA jacks for the subs? How do I go about using the high level input connector? What wires up to that?
Old Dec 2, 2009 | 11:14 AM
  #37
yitzac1990's Avatar
your amp should have come with a little connector that plugs into the High level input of the amp, with bare wires coming off it. are you talking about the 4-channel amp that has the high level input?
Old Dec 2, 2009 | 11:15 AM
  #38
OK, the speakers wire directly to the amp. So basically, the speakers wont be connected to the head unit anymore, except through the amp.
Old Dec 2, 2009 | 02:34 PM
  #39
yitzac1990's Avatar
correct. the radio will no longer be used to directly power the speakers, it will just be sending signals to the amplifier.
Old Dec 3, 2009 | 10:02 AM
  #40
cool. And yeah, my 4-channel speaker amp has high-level inputs with the connector. Does the speaker wire run from the speakers to this connector? The instructions list the rear L and R and front L and R inputs, so all I do is connect the speakers to the corresponding + and - wires on the connector?
Old Dec 3, 2009 | 10:38 AM
  #41
yitzac1990's Avatar
no, you run speaker wire from the speaker outputs on the back of the radio (the harness) to that little connector, and plug that connector into the amp, then run more speaker wires from the amp to the actual speaker. the wires running from the radio to the amp for the signal take the place of RCAs.
Old Dec 5, 2009 | 03:07 PM
  #42
3 little questions: 1. I know to run the power wire and RCAs away from each other as this can cause interference noise. Also, it says in the instructions to keep negative speaker wires off the car chassis because it can cause alternator noise to be heard. Is this true for any other wires and how can it be prevented? 2. I assume you need a power-on(blue) wire for each amp. If this is true, and my sub one is already connected, where would the speaker amp one connect to on the head unit? 3. I found an unused Optima Yellow Top battery for cheap, and my headlights were flickering as I drove after hooking it up last night? Is this just because its a new battery or what?
Old Dec 12, 2009 | 05:20 PM
  #43
yitzac1990's Avatar
1. what do you mean keep it off the chassis? do you mean like ground the ground wire to the chassis? why would you ever ground a speaker wire anyways?? haha then your speakers wouldnt work. I wouldnt worry about that little note and just run the speaker wires as normal from the amp to each speaker
2. you can splice the remote wire for the 4-channel amp off of the one going to the sub amp.
3. what do you mean unused? was it sitting for a very long time or something? Optima batteries should definitely NOT flicker from subs, especially not low powered systems like yours lol I would return it if you can, and just buy a new one from a battery store, or online. also, if you want a battery that is good specifically for car audio, I suggest a brand called Kinetik (http://www.kinetikaudio.com/2009/default.asp).
Old Dec 13, 2009 | 02:12 PM
  #44
The battery is good. Only a few weeks old. And it only did that the first time I drove it after installing it, but I asked anyway. How do you splice the wire to run to both amps?
Old Dec 13, 2009 | 02:55 PM
  #45
yitzac1990's Avatar
strip back about 1 centimeter of the existing wire, and take your new wire strip about an inch off, and wrap that around the stripped back part of the original wire. wrap a bit of electrical tape around it, then a small zip tie around it so it doesnt come undone. or you can just solder it after you twist it then wrap tape around it.
