Component Speakers & Amp
Old Nov 7, 2003 | 01:57 PM
bbizzowers's Avatar
Arrow Component Speakers & Amp
I'm looking at getting some 6 1/2" component speakers, but a friend told me if I were to get them I'd have to get an amp to push them as well. I was wondering what kind of amp I should be looking at to run a decent set of component speakers.
I know someone has probably asked this before, but I couldn't find a post on it. Thanks for your help!
Old Nov 7, 2003 | 02:15 PM
billp's Avatar
I have 6 1/2 component speakers 1 in each door 2 in rear deck with 4 tweeter all rockford using 750 watt amp rockford allso have 2 10s in the trunk with a 1500 amp all rockford the only way to go it's a ear bleeding system.
Old Nov 7, 2003 | 02:26 PM
poolshark2015's Avatar
You dont need a amp to run them. It all depends on what you want out of stereo. If you listen to it at a loud level youll want an amp so the speakers have more power so they are not distorting. I run jl amps and love them, but get somthing with a high rms wattage. You can use a 2 channel for the fronts and leave the backs on the headunit.
Old Nov 7, 2003 | 02:42 PM
TeamNeXusOz's Avatar
it would be better if you get an amp...it also depens on your h/u if your h/u has a built in amp in it then no...but be prepared for dimming lights when you bass hits...because components still put out bass
