Wtf
Old Dec 15, 2003 | 11:24 PM
imapunkclaimer's Avatar
Wtf
ok so i just installed my head unit. everything was working perfectly for about 5 hours then i was just driving along and all of a sudden the cd player turns off. i notice the clock went out also and so did the little dome light. im like ok whatever. so i get out of th car and try to lock it and it wont lock or unlock. so what the hell does this mean? did i blow all those fuses?
help would be appreciated before i try anything too dramatic.
Old Dec 15, 2003 | 11:35 PM
rbbcustom's Avatar
you probably put the power wire on the remote wire. You need to get a harness. I saw your other post and you said you were wiring to the factory harness. You need some professional help now b/c It'll take you a while to fix it yourself. I'm sorry to say that but I've been an installer for about 6 years and I've seen the do it yourselfer jobs and Im pretty sure its a mess
Old Dec 15, 2003 | 11:36 PM
OZnate's Avatar
I had an eclipse do the same type of thing. Do your headlights work? When you turn them on, does everything else fade in the interior, like dimming almost completely out? When my last car did this, my alternator was bad, and wasn't charging the battery enough until finally the battery went bad. Eventually the car died when I was on the road...NOT a good experience. Check it out
Old Dec 15, 2003 | 11:39 PM
no i bought a harness from bestbuy. i wired uit by color and asked a few people if i did it right and i did. so i was just driving and it cut out at one random point. head lights work. locks, dome light, clock and cd dont work.
Old Dec 15, 2003 | 11:43 PM
rbbcustom's Avatar
something is crossed b/c I have a harness from my distributer and I've never had any problems. Your fuse is out if you are wondering about the lights but it wont fix your problem replacing it. It'll just blow again. Did you use couplers or just twist the wires together?
Old Dec 15, 2003 | 11:57 PM
twisted the wires and electrical taped them so they dont touch
Old Dec 16, 2003 | 12:05 AM
rbbcustom's Avatar
when you twist them it is an uconsistent current and that can blow a fuse. I'd suggest using good connectors and rechecking your connections. Maybe go up 5 amps in the fuse, but I have a pretty powerfull system and never blown the fuse so some wires may be wrong in yours. Just double check and use connectors and you should be fine. By the way what head unit are you using?
Old Dec 16, 2003 | 12:18 AM
sony cdx-m800
Old Dec 16, 2003 | 01:01 AM
Lution 7's Avatar
Have you check your grounding wire connection? and any open on speaker wire?
Best disconnect all your audio wire connection first and replace all blown fuse, make sure your car electrical system is back to normal. Then Re-Install your new head unit again with double care and double sure the wire connection is correct and proper connected. Use a volt meter to test all voltage before install! Check the factory wire harness such as grounding(usually black), permanent voltage(usually yellow), ACC power(usually red), remote power(usually blue). The Sony head unit wiring is easy, it shld have a diagram n wiring harness come with it. Jus follow the diagram. Hope this help
Are u using any capacitor? or any power amp?
Old Dec 16, 2003 | 01:09 AM
no and no
Old Dec 16, 2003 | 01:37 AM
Lution 7's Avatar
No cap and no amp should be more simple and straight forward wiring connection. Check my edited msg above for checking the factory audio wire harness.
Old Dec 16, 2003 | 12:35 PM
alright ill see if i can do it at lunch break. thanks for the help
Old Dec 16, 2003 | 06:56 PM
jerzepnoy's Avatar
i have the same headunit and it did the same to me
Old Dec 16, 2003 | 07:02 PM
Marques's Avatar
a guy I work with he has a vw but he had the same problem and he took it to his vw dealer and it turned out to be a blown fuse. But his dome lights wouldnt work, the alarm would lock or unlock, the windows wouldnt go down. Hope this helps at all.
Old Dec 16, 2003 | 07:19 PM
i replacecd my 10amp fuse and everything works again. I rewired the whole headunit and retaped it and everything. i just hope it doesnt blow this time
