rattling in the doors
Old Oct 5, 2002 | 08:38 PM
agsmooth84's Avatar
i have 2 kicker solar barics and even when its not up loud the bass makes a rattling sound in both doors, i cant see exactly where its coming from, has anyone else had this problem and managed to fix it? if so how? thanks
Old Oct 5, 2002 | 10:45 PM
RacinMylancer's Avatar
ya, i've had it a bit, even though i've only got 500w of bass comin' from my trunk... SOMETIMES i've gotten a little rattle from things that have fallen into the little storage compartments on the door (silly? maybe... but worth checking), and other times, with real good bass, the little plastic fixtures/handles on the inside seem to be the source. see if it's the same for you: put like a bass mechanic CD in and wait for the rattle, then grab those plastic handle-thingies and see if it goes away. if it does, source isolated.
as far as a solution, i've yet to fix it, so... best of luck.
Old Oct 7, 2002 | 11:45 PM
jmutechnogirl's Avatar
Smile rattle and hum
you know the small plastic things on the door panel near the window controls? the thing that looks like an ash tray but it isn't? that's what's been rattling on mine. when i push on it, it stops for a few days. peace.
Old Oct 14, 2002 | 08:36 AM
J_Hawk's Avatar
Sound deaden your doors, I had the same problem until I put as much sound deadener as I could in the doors.
Old Oct 15, 2002 | 01:53 AM
OZLancerlunatic's Avatar
Yeah i completely dynamat extremed my doors.
Old Oct 15, 2002 | 02:19 AM
ancer06's Avatar
yep
i third that motion of deadening the doors with dynomat. my stock speakers made the doors rattle, but i got some JL's in the door and had them dynomat the doors while they ewre at it and it sounds clean.
Old Oct 15, 2002 | 02:55 AM
nyclancer's Avatar
I get a rattling sound from my door and my steering column and my AC Vents...lol i think they are loose wires just buzzy on the plastic.
Old Oct 21, 2002 | 06:06 AM
YouNVthis's Avatar
yea it can be a problem. my doors rattle when i bump, and my system is stock! but its probally from objects fallen into the little cubby hole in the door..check it out and see if thats it
Old Oct 22, 2002 | 08:56 PM
2wdSQL's Avatar
Re: rattle and hum
Listen to the lady. Remove this piece of plastic and the bottom piece of metal attached to it in all your doors that is the largest cause of rattles in your door panels. Remove the foam blocks from you door panels. That will solve any problem you will have with your doors rattling. The trunk and rear plastic panels behind your seats will be your greatest cause of distortion. Tighten down your spoiler as much as possible. My car is rattle free both inside and out from doing all this and dynamating my entire trunk.
Old Oct 31, 2002 | 06:22 PM
theaphextwin84's Avatar
I don't think you need to go as far as dynamating your entire door. First off, try opening and closing (completely) the window on each door and see if that affects the vibration. I have had two cars before have rattles in the window guide system. Otherwise listen very very carefully to where you think the vibration is coming from and you can spray in sound deadeners to hot spot problems like that. Much cheaper and still works.
Old Nov 1, 2002 | 03:48 PM
LBLancerDude's Avatar
my window controls rattle
Old Nov 15, 2002 | 07:44 PM
OZRACINGWV's Avatar
I have a weirder one:
Not only do my doors rattle when I have the stock system at a good volume, whenever I close my doors or hit a sharp bump I get a loud metallic clank that sounds like an extreme version of the rattling. I have taken it to the dealership and they shrug their shoulders and tell me to just deal with it. I want to rip the doors off and find out what is making the noise sometimes. It drives me nuts on days when I want to listen to the car. Oh well, food for thought....
Old Dec 16, 2002 | 12:05 PM
KTRLancer02's Avatar
My doors rattle too, its very irritating. This is with the stock unit, can you believe what it would sound like when i get a system? Jeepers!
Old Dec 16, 2002 | 12:08 PM
HobieKopek's Avatar
Opening the doors is a piece of cake. If you' definitely think it's in there then go for it. The only difficult part is putting the weatherstripping back on and it shouldn't take more than a couple minutes.
Old Dec 17, 2002 | 05:05 AM
on3ofak1nd's Avatar
The plastic dash cover above my rear seats is definitely one of my main rattle sources, trying to decided how to best solve it...
Another huge problem I have are my tail lights, they create an insane buzz, it can't really be heard from the inside but outside it's sick, in the bad sense. Any suggestions for fixing that?
-wes
