Audio Help!!
Old Jul 30, 2004 | 11:47 PM
demock's Avatar
Audio Help!!
I have 4 6.5 4 way pioneers in my OZ and their max is 220w a piece and I was wondering if any one could tell me what size is a good amp that would push these! also how to hook it up!!!
Old Jul 31, 2004 | 01:22 AM
ghostrider's Avatar
What's the RMS on the speakers?
Old Jul 31, 2004 | 05:34 AM
demock's Avatar
The RMS wattage is 50.
Old Jul 31, 2004 | 05:45 AM
Sentinal's Avatar
50 watts RMS isn't much wont take a lot to power that... I would suggest JL Audio 4 chan amplifier
http://www.acaraudio.com/product_inf...roducts_id=181
Just keep the gain on it at about half way and you should be good Its a great quality amp and gives you room to upgrade your speakers later if you choose to do so. Install is not too hard just run the Hot wire from your battery to wherever you choose to mount your amp make sure you have a good grounding wire bolted to the chasis of the car run your RCA from the deck to the amp and then wire from the amp to each speaker. If you have never installed an amp before you may want to have someone help ya.
Old Jul 31, 2004 | 06:45 AM
Archangelite's Avatar
but damn thats expensive. just go with a multi channel alpine
Old Jul 31, 2004 | 05:46 PM
SK Lancer's Avatar
Alpine is expensive, too...
Find a Memphis PR4400.. 4x75W RMS and it will be cheap!!
Old Jul 31, 2004 | 11:37 PM
demock's Avatar
I found some 4 channel amps for $100 on ebay and etronics.com. Thanks for all the info!!
rmrEVO
Apr 22, 2012 11:16 AM
Seifer780
Lancer Engine Tech
Sep 19, 2010 10:43 AM
user 8367547
Australian Forum
Jul 31, 2005 03:45 AM
