Removed Ver.2 Piggyback
Old Apr 24, 2006 | 10:36 PM
jsfour's Avatar
I took mine out a while back too. The car just ran like shi*. Good gains but it was rough and i took a hit on mpg.
Old Apr 26, 2006 | 09:57 PM
intcoverup's Avatar
Well, it looks like I'm letting her go. If anyone is interested, PM me.
Old Apr 27, 2006 | 11:06 AM
Wallesasuaz's Avatar
pm'd
Old Apr 27, 2006 | 05:48 PM
ROCK's Avatar
We have software upgrade. We worked it out this week. I have 3 test cars and 2 worked great. Jutt waiting for the last guy to report back be fore we release it. Hang in there a little bit longer.
ROAD/RACE
Old Apr 27, 2006 | 06:17 PM
TEJ's Avatar
TEJ
ROAD/RACE
Looking foreward to it. Once again rrm comes through in the clutch.
Old Apr 27, 2006 | 07:13 PM
intcoverup's Avatar
What are the gains from the upgrade?and how can I get the upgrade?
I still have hopes.
Old Apr 27, 2006 | 09:59 PM
sykou's Avatar
Originally Posted by intcoverup
Hey guys, I re-installed the PB today. Engine died after 2 minutes of idle. Car Idled for 10 minutes and was driven for 20 minutes, then turned off and it started back up clean.
I took pictures of the wires and the connections as well.
I timed my 0-60 3 times and this is what I got
Without PB (AC on)- 11:340
With PB(AC on)- 11:404
With PB(AC off)- 10:583
I was running with 93 octane.
I know the times aren't all that accurate.
Am I supposed to gain more?
thanks
Uhh i hope you didn't leave the wires like that...please tell me you taped them..
Old Apr 27, 2006 | 10:36 PM
ROCK's Avatar
WOW. THAT IS NOT INSTALLED> Those wire carry such small voltage, even milivolts. No way that is gonna work correctly. IF you cannot install it correctly go to a pro. That is the worst install I have ever seen!!!!! Seriously. I am not trying to make you feel bad but install like that makes us look bad and is awaste of your time. Call us if you need some tips but instructions pretty much tell you how critical the connections are!!
ROAD/RACE
Old Apr 28, 2006 | 08:02 AM
he he.. someone is in trouble.
Old Apr 28, 2006 | 08:23 AM
blaze_125's Avatar
What's wrong with those connections? Aside from not being sealed from each other, they are all getting a good connection if you ask me. Sure they're not soldered, but the wires are stripped on a fair enough lenght, and they seem twisted fairly tight.
Old Apr 28, 2006 | 08:45 AM
This Thread really affects the Vendor.
Old Apr 28, 2006 | 09:06 AM
comatose721's Avatar
they appear to be twisted on (some of them) very sloppy. solder would be most effective; but not all of us have acess to a soldering gun. i dont think it's the worst i've ever seen but there is room for improvement.
Old Apr 28, 2006 | 09:11 AM
Looks like it's hooked up for just testing. Regardless, Soldering isn't actually necessary, but some Electrical tape should always be used, even if it's just to test the connections. Never leave the connectinos open like that, cover them to be safe.
What would happen if one of those connections just happen to touch one another by mistake while the car is turned ON and you're looking away?
Black Tape! USE IT
Old Apr 28, 2006 | 09:15 AM
...then i would tell him i have an extra ECU sitting on my bed that i would let go of for $100 hahahaha
Old Apr 28, 2006 | 12:42 PM
intcoverup's Avatar
The car was off, battery disconnected when that picture was taken. I had JUST taken it off and pictures were requested to make sure I was getting the right wires. I just connected that for pictures and took it back off. I actually had it on there right when I was using it. That was JUST FOR THE PICTURE. I'm not that stupid, no worries.
I had NO intention of making RRM look bad in any way. Once again, this connection was ONLY FOR THE PICTURE. Not for use!!!
