e-manage - idle question
Old May 22, 2006 | 12:31 AM
Go_Lancer_Go's Avatar
hey, my idle on the emanage is still a lil sketchy, it doesnt really matter but they zero'd it out and it still is hunts for steady idle, i wanna know if u guys did n e thing special to urs to make it not like that. I have 370cc RC Injectors in my car.
Old May 22, 2006 | 08:12 AM
Blacksheepdj's Avatar
Maybe lose some gas? With those injectors, don't you run ULTRA rich at idle?
Old May 22, 2006 | 05:15 PM
no i dont actually, at idle on my wideband the a/f usually goes around 17-21
remember w/ a emanage it allows u to make a base map then go from there/
Old May 22, 2006 | 06:57 PM
impetus19's Avatar
what ratio correction are you using for those injectors on your emanage? It seems like you are running pretty lean for that size injector.. Have you removed the restrictor plate on the MAF sensor?
Old May 22, 2006 | 07:44 PM
well idle is jus idle i was told i would running leaner around idle
I have not removed the restrictor plate, would that honestly make a difference and how?
Old May 22, 2006 | 07:47 PM
impetus19's Avatar
It would only make your idle run leaner because it is letting so much more air into the engine. So that isnt the problem.
Do you have an adjustable fpr? Do you know what the fuel pressure is set at for idle?
Old May 22, 2006 | 11:53 PM
im not sure, ill try and get my map and ill send it to u....
