SAFC. whos using it to tune na?
Old Aug 13, 2006 | 01:58 AM
revolt4revolver's Avatar
working on tuning the lancer with the safc.
who has tuning points and tips for tuning with it?
i found an old post by maximum17... hes running super lean im thinkin i dont want to even cme close to his map.. so pehaps ill cut 2/3 of his points on each rpm point.
at what point is higher octane needed?
thanks guys!
Old Aug 13, 2006 | 07:53 AM
airlinevomitbag's Avatar
Just start subtracting. No one will have the points that work for you. I have a 190 pump and a fuel pressure regulator but no gauge (beats me what the actual pressure is but it works so..) and the MAS screw is backed out pretty far on mine + no cats.
On the much maligned narrowband I have it so I am in the yellow on cruising and 1-2 bars green WOT. I pull 33mpg with this setup on a 5spd. I also have an EGT which at 75-80mph (cruising speed on the way to work) is a hair below 1300 degrees.
EDIT: I still use 87 octane too. You'll notice the car wakes up the more you subtract too.
Old Aug 13, 2006 | 01:13 PM
so tuning na, with no wideband whats the safest amount i can subtract?
im getting a wideband in a week or so.
Old Aug 13, 2006 | 01:25 PM
The narrowband will read lean. Subtract until it reads in the high yellow while cruising and a bar or two green under WOT. There is no magic number. Mine change from summer to winter.
Old Aug 13, 2006 | 02:05 PM
thanks. i just trimmed 3-4% less fuel and i feel the difference already!!!
evo ippo
Feb 5, 2007 12:44 PM
chizcwish74
Jul 28, 2005 03:10 PM
mattfl
Feb 27, 2005 07:28 PM
