Rrm Piggy
Old Mar 27, 2007 | 12:39 PM
chiguy22's Avatar
Rrm Piggy
im kinda having a problem wit my piggy back...after it got installed i left it running for twenty min or so...i drove it around as well and it seems to act like it wants to turn off...does anyone know what i mean???its been doing this for quite a bit...like for instance i turn it on in the morning...i warm it up...and it turns off...so i turn it on again it stays on..but den it tries to turn off...over and over...PLEASE HELP!!!!!!!!!!!ANY HELP WOULD BE GREAT!
Old Mar 27, 2007 | 12:42 PM
crypto's Avatar
Former Vendor
search.
i just did a bunch of research on the piggy cos i'm buying one. what is happening to your car is normal. it takes a good week for the piggy back to completely learn your car. During the learning period your car is gonna idle funny, and probably stall a few times.
even after the piggy has learned, you still may experience a rough idle every now and again.
Old Mar 27, 2007 | 12:55 PM
chiguy22's Avatar
its been well more then a month...and it just keeps sputtering....just as the same as i first got it in...
Old Mar 27, 2007 | 01:00 PM
crypto's Avatar
Former Vendor
call RRM, they will gladly help you.
you may have made a mistake installing it
Old Mar 27, 2007 | 01:02 PM
blaze_125's Avatar
Which version of the piggy are you using?
How many times have you gone through your connections to ensure everything was soldered properly?
Are you getting a CEL?
Did you install anything else the day you installed the piggy?
Feed us some info, and we'll gladly troubleshoot with you.
Old Mar 27, 2007 | 01:12 PM
chiguy22's Avatar
i have the ver.2 i honestly havent checked it yet...and i got the big bore fuel rail installed tat day...and i havent put da CEL on yet...
Old Mar 27, 2007 | 01:15 PM
blaze_125's Avatar
Check your wiring.
MAke sure the fuel rail is properly installed, not leaking, fuel lines aren't bent.
What CEL are you going to put on?
CEL means Check Engine Light. My question was: did it come ON?
Old Mar 27, 2007 | 01:18 PM
chiguy22's Avatar
oh my bad i meant da CEL eliminator...ill check the wiring..well cuz of my headers its been on...i have kamakazie heads and i was told it didnt fit.....?
Old Mar 27, 2007 | 01:35 PM
blaze_125's Avatar
in that case, go to auto-zone or something and get the codes.
1 code will be for the header, and let us know if there is any other codes coming up.
Old Mar 27, 2007 | 01:44 PM
chiguy22's Avatar
cool thanks...ill keep u posted
Old Mar 27, 2007 | 03:53 PM
ROCK's Avatar
Sounds like vacuum leak on fuel rail and not the piggy. Again piggy seems to get a bad wrap for something that it does not cause. Regardless, check connections. Onlyt guys with these problems are guys who goofed up installing it.
ROAD/RACE
Old Apr 4, 2007 | 11:35 AM
DickMorgan's Avatar
ROAD/RACE
VERY TRUE!!!!!!! i think rock is speaking about me j/k
But yeah i mixed up 2 wires and had problems.....but RRM found my mistake and i couldn't be more happier with the mod
Old Apr 4, 2007 | 12:49 PM
chiguy22's Avatar
yeah...thanks alot guys!i really do appricate everyones help!i got da problem fixed...it was da wiring...i guess i goffed.lol again thanks
Old Apr 5, 2007 | 07:25 PM
PGDlancer's Avatar
lol, good to hear all is good in PB land. I was gonna say I could help you if it causes any more problems.
Old Apr 5, 2007 | 07:50 PM
kungfugirl's Avatar
piggyback gave me good power, once u have it right, enjoy
