Guages- Power Question
Old Apr 30, 2007 | 10:54 AM
crypto's Avatar
Former Vendor
Question Guages- Power Question
I have just installed 2 new guages. A narrowband A/F ratio guage, and a turbo/vacuum guage.
The turbo/vacuum guage is working, but there is no backlight, and the A/F isn't working at all.
the reason being i can't figure out how to get power to them.
I tried cutting the wires going into the cigarette lighter and using them as a power source, but i still don't have power.
Here is a diagram of what i have done, and what i think it right. I have cut of the ends of the wires and just spliced the guages directly to them, so there is no power to the cigarette lighter.
I must be doing something wrong, cos like i said, i have ZERO power to the new guages.
Old Apr 30, 2007 | 11:24 AM
SnapDragun's Avatar
How many wires on the gauges?
Old Apr 30, 2007 | 11:25 AM
ambystom01's Avatar
There's install instructions on here, look in the evo how-to forum. Might I ask why did you bother getting a narrowband and a boost gauge? You don't have a turbo and the A/F is good for nothing but a light show.
Old Apr 30, 2007 | 11:29 AM
crypto's Avatar
Former Vendor
^i got them for free. another member needed a stock A-pillar so he traded me the guages and pillar for my stocker. Also i use the vacuum guage cos i got that piggy hooked up and FPR, so i kinda want to keep a check for vacuum leaks. And the narrowband is pretty much just for show. But like i said, it was free
and wires on the guage. 2 for power. 1 to go to the O2 sensor. So 3 in all.
And i couldn't find instructions. All i saw was "tap into cigarette lighter for power"
theres no instructions on how to do that
Old Apr 30, 2007 | 11:31 AM
ambystom01's Avatar
Here ya go, this is the best one I've found in a while https://www.evolutionm.net/forums/sh...ad.php?t=98114.
Old Apr 30, 2007 | 11:34 AM
crypto's Avatar
Former Vendor
^thats perfect mate. i will re-hook up the cigarette lighter and use the dimmer as the power source. Thanks
Old Apr 30, 2007 | 11:37 AM
SnapDragun's Avatar
Ok so you have a ground wire, +12V constant, switch wire (trigger on wire), and the sensor wire. u can tie the +12V and the switch wire to the ciggy positive wire and it will shut the gauge on when the key is in the ACC positon. The way I did it is I found in the fuse box a fuse that was allways power whether the car was on or off and tied the +12V constant there. Then I tied the switch wire to the green wire on the dimmer switch so that my gauges cut on only when my parking lights and/or headlights was on but u can tie this one to the ciggy positive wire.
Installation
Old Apr 30, 2007 | 11:47 AM
hopper's Avatar
I always use a add a circuit for feeding power to accessories, This way you have a fuse for it. and your not splicing up factory wiring. you can get them at advance autoparts or napa or whatever for around 7 bucks. just get a noid light, if you don't already have one and find out what fuse comes on with your key
http://www.partsexpress.com/pe/showd...number=071-580
Old May 8, 2009 | 12:16 AM
Chameleonzero's Avatar
i used the one for the ignition, i believe it was the white and yellow wire
sexydexy_evo4
Oct 3, 2016 08:37 AM
TS Goofy
Dec 13, 2013 08:28 PM
OX
Aug 29, 2009 02:10 PM
avo3vom
Aug 12, 2007 08:56 PM
smokedmustang
211
Mar 16, 2006 04:51 AM
