ecu problem?
Old Jan 13, 2008 | 03:59 PM
pandagsx's Avatar
ecu problem?
I have a 2002 lancer oz it has a MIL on and the code is warm up catalyst below threshold. I tested the o2 sensor and it is working exactly how it should. There should be 9-11v at pin 3 on the A/T ecu at idle I have that but when you rev the engine your supposed to have 9-11v momentarily and then it should jump up to source voltage, or what ever the alternator is putting out and it will not go above 11v.
Between pin 41 and pin 3 there should be 4.5-8 ohms and I have 10 ohms between the two pins should I declare the ecu the problem, or could it be something else. power and ground to ecu is good.
Old Jan 14, 2008 | 01:28 AM
Evo Villain's Avatar
is ur cat still good?
Old Jan 14, 2008 | 12:38 PM
SLVROZ_03's Avatar
Just curious, are you on the OEM battery?
Old Jan 14, 2008 | 12:42 PM
atilla's Avatar
what's the code? it's probably the cat and not the ECU.
Old Jan 15, 2008 | 08:14 PM
mirage 4g93t's Avatar
was their a recall for this?
Old Jan 15, 2008 | 08:44 PM
atilla's Avatar
there was a recall for a ECU flash on the 02-03s but i do not remember the exact reason. when i bought mine i noticed a sticker saying the flash had been done.
