EcuFlash tunning help
Old Aug 11, 2008 | 07:38 AM
nestoledo's Avatar
my setup is:
turbo custom
injectors 440 cc
pump walbro 255
ecuflash
my problem is the following one
load
0-100 it is ok
but 100-180 the AFR change of
2psi - 15 AFR
3psi - 16 AFR
4 psi - 17 AFR
before ecuflash i running with apexi neo and be fine at 10psi
now i change the maps with ecuflash but i cant run fine
these is my maps, please tell me that I can move to run fine
Thanks you
sorry for my English, i hope understand me
these are my maps
Old Aug 28, 2008 | 01:02 AM
sykou's Avatar
hmmm from looking at your map you might wanna change the ranges you have your loads defined as... ex: you got ...60 70 80 then 153?! that is a big jump. You should try something like this...10 20 40 60 70 80 90 100 120 130. Are you seeing anything near 180% load? post a video of one of your logs showing the load, rpm, wideband AFR, etc.
Also when you add load values in the load % area you also have to do the same int he ingintion tables. Cuz if your seeing 120% load your ECU will only be able to determine how much fuel to send btu it wont know what to do with the timing.
Do you have a fmu? i think your fpr is not allowing enough fuel out. even though you got bigger injectors and a upgraded fuel pump if you got a stock fpr it will still limit the fuel pressure.
Old Aug 28, 2008 | 07:31 AM
senate6268's Avatar
How do you know how much load your engine is under? Are you datalogging with EvoScan or any similar software that reads your engine load from the ECU? Most turbo Lancer setups don't see more than 120-130% load from the ECU and that's at like 10psi. You might want to lower your load values and also adjust your ignition values like sykou stated above.
Old Aug 29, 2008 | 02:10 PM
nestoledo's Avatar
ok, finaly i can run at 10 psi. but for do that i was need to move to limits the maps of fuel and timing, also move to 0 the load open loop. and resize injectors the car run fine and very fast
Old Oct 9, 2008 | 12:32 AM
03LancerUTI's Avatar
ok so ive heard ecu flashing or piggyback, i understand that piggy back is limited and more so a plug and play while the flash you can change more. im starting to mod my car and i want to get into flashing but i want to understand it more so i know what im getting into.
Wmu240
Dec 18, 2015 10:18 AM
superkizuna
Oct 30, 2012 03:07 PM
07EvoIX
Oct 28, 2012 12:49 PM
Raceghost
23
Dec 17, 2009 11:00 PM
razorlab
Apr 1, 2007 08:08 AM
