help with iac valve...
Old Aug 25, 2009 | 01:33 AM
crf inc.'s Avatar
my idle air control valve has been going out for almost 2 years now... its use to only act up every once in a while, after a long drive or on really hot days.. my idle would start fluxuating between 400 to 700 rpm... well the last couple weeks its been doing it pretty much every day.... ive been shopping around for one but they usually run about $300 to $350. i found what i think is an iac valve on rpw for about 165 au. whitch is about $135 american... just want to be sure it is what i think it is before i order it because they call it something different..."idle speed control motor"... does anybody know if this is indeed what i need?
heres the link...
http://www.rpw.com.au/shop/index.php...mart&Itemid=31
Old Aug 25, 2009 | 07:31 PM
crf inc.'s Avatar
damn 25 views and not one reply??? what the deal? anybody? anybody? bueller...... bueller......
bueller?
bueller?
Old Aug 25, 2009 | 07:54 PM
DragEvo9's Avatar
same boat your in.. I wouldnt go over seas for it tho...
Old Aug 25, 2009 | 10:18 PM
crf inc.'s Avatar
well its about $135 shipped... if i can get it for that cheap, i dont mind ordering overseas
Old Aug 27, 2009 | 05:12 PM
mcgarvey's Avatar
Doubt it's the IAC. Check your throttle cable first, there is an extremely common problem with the cables sticking when hot
Old Aug 28, 2009 | 11:06 AM
crf inc.'s Avatar
Thanks but I'm 100% sure its the iac valve.. Its been setting off my check engine light for about two years now.. I've done a diagnostic check and everything...
Old Aug 28, 2009 | 12:06 PM
imalancerman's Avatar
Hey, my cars been pulling this too. It will actually only go down to 1000rpm and fluctuates between 1k and 1200. Then, if you tap the gas while its idling like this, it'll go down to about 650, and fluctuates between 650 and 750. I thought it was just because I have a coolant bypass mod done but it didnt do it last year. No cels either. I have an extra iac i could use if we really think this is the case. And no its not my throttle cable sticking. That would just hold it above normal idle rpm, not cause it to fluctuate.
Old Aug 29, 2009 | 12:23 AM
crf inc.'s Avatar
Hey just curious but what does your car normally idle at? And yeah definitely try swapping it out if you have a extra one laying around..
Old Aug 29, 2009 | 03:03 AM
um i think it seems to idle normally at 650, albeit i do have a stick and they seem to idle lower than automatics.
Old Aug 29, 2009 | 02:21 PM
crf inc.'s Avatar
yeah same here... but thats weird that it never set off you cel... but mine use to do the same thing, it would raise the rpm up to around 1k like it was trying to prevent the idle from fluxuating.. but wont even do that anymore.. it just fluxuates between 450 and 650/750
Old Aug 29, 2009 | 02:27 PM
TS8's Avatar
TS8
I found one here on the forums for a better price.
Old Aug 30, 2009 | 12:09 AM
crf inc.'s Avatar
how much is better?
Old Aug 30, 2009 | 01:19 AM
Shoot, i dont think mines bad, id sell my extra for a reasonable price maybe.
Old Aug 30, 2009 | 12:55 PM
crf inc.'s Avatar
whats reasonable for a used one? yours is used right?
Old Aug 30, 2009 | 01:57 PM
Yes my extra has 50k on it and came off a perfectly running motor. Whats reasonable to you?
